Engine bay noise
Old Jan 21, 2008 | 11:35 PM
bigd31388's Avatar
if it does it while there off then idk.. but i know mine does it with the ac/heat on
Old Feb 6, 2008 | 12:32 PM
9ball's Avatar
Same here. I noticed a "click" every ~20s but only when the heater is on.
Old Feb 6, 2008 | 08:25 PM
Billy@EnglishRacing's Avatar
sounds like the fan clutch activating
Old Feb 6, 2008 | 08:42 PM
krnkimchi702's Avatar
thank you!!! finally someone that realizes its a fan clutch.. lol
Old Feb 6, 2008 | 10:38 PM
SmoothdrJay's Avatar
Yeah
Old Feb 6, 2008 | 10:46 PM
CamShaft's Avatar
a/c clutch :P correction :P
Old Feb 6, 2008 | 10:57 PM
what?!?!
Old Feb 6, 2008 | 11:51 PM
Bonburner's Avatar
can sum1 explain this a bit more please?
i went to the mitsu dealr and we heard it too, and my dad was nagging me about dat a bunch - he doesnt like mitsu at all and i really wanna get this lancer, so until i find out what that is ... D:
guna b hard convincing him to get me dat car, haha
Old Feb 7, 2008 | 05:28 AM
nj_08_gts's Avatar
What does he like instead of ? As much as it might pain you to hear this: your old man may be right.
I was messing around with this the other day and it made that sound only if I left the climate control on "Auto". If the climate control was off I didn't hear a peep.
Old Feb 7, 2008 | 07:49 AM
Erikku's Avatar
isnt the sound because of the timing chain?
Old Feb 7, 2008 | 10:00 AM
CamShaft's Avatar
its the clutch on the a/c compressor. This compressor only runs when needed. Once pressure drops in the a/c system the sensor/ecu will tell the a/c compressor clutch to kick in and start building pressure.
This is completely normal. And we don't have a fan clutch. Its an electric fan.
The clutch is an electromagnetic type. Ince energized it sucks together (click) and the starts running the a/c. Manually turn off the a/c and run it, you won't hear this click anymore. If you are buying this car the dealer should be able to tell you this!
Old Feb 7, 2008 | 10:43 AM
That noise is the constant tic you hear. Small price to pay for piece of mind. A chain is much better than a belt. I AM tired of people asking if i drive a diesel though...
Old Feb 8, 2008 | 12:23 AM
CamShaft's Avatar
if I am not mistaken, the ticking noise you hear constantly is the lifters?
The timing chain has tension on it and therfore should not make that amount of noise, if it does then you are in for some trouble. A chain is a little more noisy than a belt but not as noisy as the constant ticking you hear.
Old Feb 8, 2008 | 07:52 AM
WhiteGTS18's Avatar
yeah i get that really loud ticking too. one time especially after like an hour long ride and the cabin smelled of burnt rubber too which i didnt like very much at all. this car kinda upsets me being that one it only has 11k on it and ive changed the oil every 3000 with mobil 1 and it's doing things like this.
Old Feb 8, 2008 | 09:34 AM
CamShaft's Avatar
the ticking of the lifters is normal. If you are really that worried about it take it to the dealer.
