dumb question...
Old Feb 28, 2008 | 02:10 PM
KBkilla0006's Avatar
dumb question...
okay, i had new rims, tires, and RRM springs installed on my car a few months ago. Sadly, I havent gone to get an alignment (I know I need one, because its been pulling to the right). However, when i am driving and then have to come to a stop, my steering wheel will start shaking and rumbling after hitting the brakes. It does get more violent at higher speeds, but its not unbearable. Anyone know if the alignment will fix this issue, or is this being caused by something else?
Thanks
Old Feb 28, 2008 | 02:27 PM
SLVROZ_03's Avatar
I might, or it might not. Your new rims could have lost a weight or something. Start by getting the alignment, then if it conitnues go to the place where you had your rims/tires put on.
Good luck
Old Feb 28, 2008 | 02:29 PM
Mistaken's Avatar
You know you need an alignment so start there...
Old Feb 28, 2008 | 02:31 PM
krnkimchi702's Avatar
sounds more like a balance rim issue get ur wheels balanced and an alignment.. get ur **** straight son lol
Old Feb 28, 2008 | 02:54 PM
lol, okay ill quit being lazy.
Old Feb 28, 2008 | 03:15 PM
Blacksheepdj's Avatar
First off, get an alignment (and some camber bolts so they can actually align the front).
Second, think about the brakes. You described the classic "warped brakes" symptom. Does it ONLY happen when you hit the brakes? Could be that you overheated a rotor. If that's the problem, it won't really clear up until you get new rotors/pads. But getting the rotors resurfaced could help if it is the problem.
Old Feb 28, 2008 | 03:23 PM
OOOO get the rrm slotted rotors and tell us how they perform LOL
Old Feb 28, 2008 | 03:52 PM
nunyas's Avatar
yup... what Black said. If you're feeling the vibration ONLY when you hit the brakes then you most likely have warped rotors. The cheap way out of that is to have the rotors turned, but if they're warped too much you'll have to get new ones.
Old Feb 28, 2008 | 06:08 PM
F*** it imma buy the rrm ones if the alignment doesnt fix it
Old Feb 29, 2008 | 03:20 AM
CamShaft's Avatar
if you got the rotors too hot they might not be able to machine them due to hard spots.
But definitely sounds like warped brakes for the pulsing, shaking wheel. You only changed springs, so the slight pull to the right would be for that. So alignment first, then see what happens.
Old Feb 29, 2008 | 06:35 AM
Get pads too then. If the rotors are bad, the pads are probably bad too.
