egg smell?
Old Mar 2, 2008 | 09:08 AM
lancer2show's Avatar
egg smell?
i pulled a code today and it said i needed to replace my first 1st o2 sensor. than the guy that pulled my code for me said its my coilovers. i was like ummm i really doubt that. he still insisted it was my coilovers.
i know for a fact its not the coilovers. is the egg smell coming from a bad o2 sensor? thanks
Old Mar 2, 2008 | 09:15 AM
cij911's Avatar
Are you using a catalytic converter? If you are smelling a sulfur like odor, you most likely are not running a cat. or your cat. is going bad....
Old Mar 2, 2008 | 10:09 AM
WangMan's Avatar
Take it to a real mechanic who knows what the hell he's doing. Coilovers.... psh
Old Mar 2, 2008 | 10:45 AM
ambystom01's Avatar
Sounds like a cat converter issue.
Old Mar 2, 2008 | 11:27 AM
o ok thanks guys!
o ya my code was pulled for free from autozone. their not real mechanics anyway..haha.
Old Mar 13, 2008 | 03:55 PM
Synthrocker's Avatar
Originally Posted by lancer2show
o ok thanks guys!
Coilovers? Maybe he ment CoilPACKS? they control the spark to your spark plugs. You have two, and each one contols 2 cylinders.
What I would do, if you wanna do it yourself and not bring it to a shop is.
Throw some injector cleaner in there, clean up the injectors and o2 sensors (sometimes works, sometimes is a temp fix) I start with this when I'm not the shop scan tool and get an O2 code. If that doesent work, replace the o2 sensor.
Bank1 bank 2 refer to what cylinder head its on, so we have a 4 cyl so it would be bank 1, the 2nd number refers to what o2 sensor itself is. 1 is the 1st one, in the manifold, 2 is the one after the cat converter, it can also be called a "cat efficianty sensor". If that doesent work, inspect your spark plugs, see if they look okie. Actually, you know what, do that 1st. lol
And if all else fails, replace the coilpacks and the two wires.
BTW after you perform each task, dissconnect the battery for a lil while- cheapo way of resetting the light.
goodluck ^_^
Old Mar 13, 2008 | 04:13 PM
apexlancer02's Avatar
deffinitly the cat i had the same problem untill i got a high flow.
Old Mar 13, 2008 | 04:22 PM
o ok thanks guys!
And if all else fails, replace the coilpacks and the two wires. Also, u can unbolt ur exhaust and see if the cat in starting to break up, careful though, sometimes those bolts can be hard to get off
goodluck ^_^
Old Nov 7, 2008 | 09:19 AM
Green_Bandit's Avatar
Do you happen to remember the code you were throwing? Was it P0135 by chance?
Old Nov 7, 2008 | 09:27 AM
i dont remember man but i remember changing the spark plugs and it stopped smelling.
Old Nov 7, 2008 | 09:36 AM
4g94T's Avatar
turbo with cats? It's robbing horsepower!
Old Nov 7, 2008 | 09:39 AM
im running straight pipes, but i took off the turbo kit for some warranty purposes.
i agree who runs turbo kits with cats haha jk
Old Nov 7, 2008 | 09:42 AM
ambystom01's Avatar
I have a catted TBE. You don't lose nearly as much power as people think and in all likeliness, you don't lose any at all. I'm pretty sure our local tuner/subaru god did some comparisons between catted and catless and unless you go with a massive turbo, the difference is so minor you couldn't possibly notice it.
Old Nov 7, 2008 | 09:50 AM
mirage 4g93t's Avatar
i agree removing the cat doesnt make a difference but 5whp is still a good gain in my opinion without the cat. it also helps with spool too.
Old Nov 7, 2008 | 09:52 AM
ambystom01's Avatar
There's no proof that you gain 5whp though, people have just the assumption that a cat is a restriction thus they need to get rid of it. I suspect that the flow difference between a test pipe and high flow cat isn't enough to justify the noise, smell and legality issues that come with a catless setup.
