Sqeaking/Rubbing sound when I turn the steering wheel
Old Mar 5, 2008 | 09:23 PM
tdanmorello's Avatar
So, out of nowhere today my steering wheel started making this loud rubbing/squeaking noise whenever I start turning. I happens when the wheel is turned left or right. It doesn't do it straight through the whole turn but it does it most of the revolution. I thought it might be the steering wheel rubbing against the big plastic part behind it, but it sounded a little further down.
I don't like the sounds of it at all . It just happened this afternoon and will see if it does it tomorrow. Has anyone else run into this one?
Old Mar 5, 2008 | 10:33 PM
Hawnz22's Avatar
Sounds like my old 81 Malibu cause the power steering would leak... did u check the power steering fluid?
Old Mar 6, 2008 | 09:20 PM
so as of this morning it stopped doing it. But, to make sure my bases were covered...I checked the power steering fluid, all the lines I could see and under the car for possible leaks.
Everything looked 100% so maybe it was just some stupid, new car squeak/rattle that went away.
Old Mar 9, 2008 | 10:28 PM
stupid noise started up again yesterday. It's been raining a lot the past couple of days. I sounds like it could be a wet, rubber boot/or piece some where in the steering column or something.
Does this seem possible?...since I think it dried out today and stopped doing it again lol. If not, gonna call the dealer.
Old Mar 9, 2008 | 10:30 PM
Billy@EnglishRacing's Avatar
does it only do it at full lock?
Old Mar 10, 2008 | 04:35 AM
Lancer_GTS's Avatar
Is it also very humid out there, and possibly the interior is is also taking in some moisture causing it to happen?
Old Mar 10, 2008 | 07:09 AM
WhiteGTS18's Avatar
no i know exactly what your talking about man and it has happened to me more then once on rainy days. also i will sometimes get the smell of burning rubber also. i think rain water is getting up in the engine bay and soaking the belt causing it to squeek and loose grip also causing it to burn rubber. it is very annoying and a new car should do neither of these things. i wish they made a recall or something for it. like new underbody panels that keep things dryer down there.
Old Mar 10, 2008 | 08:23 AM
CamShaft's Avatar
maybe you belt tensioner isn't as strong as it should be, it rains here lots and not problems with it so far.
Old Mar 10, 2008 | 01:25 PM
WhiteGTS18's Avatar
i wonder if it has anything to do with the RRM pully that i put on there. ill have to check the belt and stuff when i put my rims back on in a few weeks.
Old Mar 10, 2008 | 07:07 PM
CamShaft's Avatar
the pulley could be it... try the stock one and see if it goes away... easy to do, just take ur hose and spray the belt., careful not to douse the Alt.
c08
Jan 2, 2017 11:45 AM
Monstertrek
Oct 12, 2016 09:23 AM
irwintan27
Sep 10, 2016 06:19 AM
Ryley
Sep 5, 2015 02:50 PM
EVOQUICK
Jul 22, 2012 08:55 PM
