Oh no! I'm disappoined in mitsubishi
Old May 22, 2008 | 07:25 AM
ashun22panda's Avatar
I do not know if it is my fault or mitsu, but my electric gas meter on my LANCER GTS has been broken. It always says my gas tank is full.
I am the retard who believed that his gas milage has greatly improved but it hasn't. I drove until my whole tank was empty and had no clue. Luckily i was near my house and i figured out the problem.
I wonder if there is a fix for this problem. i filled up my gas tank and it was normal again. thank god i was near my house =( then again. i should have noticed.
Old May 22, 2008 | 07:31 AM
Kurt's Avatar
Take your car to the dealership and let them look at it.
Old May 22, 2008 | 07:35 AM
Turbolover's Avatar
Mitsu. has a real problem w/warranties, but you seem safe. Take it in!
Old May 22, 2008 | 03:21 PM
Blacksheepdj's Avatar
Don't be disappointed in - things break. That's why every new car comes with a warranty.
Old May 22, 2008 | 11:46 PM
Nathan0490's Avatar
I check my "Distance Till Empty" or DTE as well as keeping an eye on the actual meter, I wonder if both failed on you?
Old May 23, 2008 | 07:51 AM
my distance till empty keep going up. funny how i told my friends that my gas milage was godly. they both failed. yes. i know im gonna take it back to the dealer but im too busy. i'm gonna fill gas up every 7 days.
Old Jun 12, 2008 | 05:53 AM
kraig's Avatar
Probably something as simple as a wiring fault or sensor failure. At worst the dash display has a malfunction. All covered in the B2B warranty so shouldn't be a problem, or hard to fix if they aren't complete morons.
Old Jun 12, 2008 | 08:58 AM
DrivinMissDaisy's Avatar
Could be the meter next to the fuel pump got stuck in the full position when you filled up. And when you filled up again it just knocked it free.
Old Jun 12, 2008 | 09:33 AM
bluewaterDEMON's Avatar
This problem should be added to the known problems list for 2008s. Mitsubishi knows about this, and has issued a TSB on this matter.
No. TSB-07-13-009
DATE: November, 2007
MODEL: 2008 Lancer
On a small number of affected vehicles, the fuel level float arm may contact a vapor hose inside the fuel tank causing the arm to stick in the full position regardless of the amount of fuel in the tank. The customer will complain that the MIL is illuminated. They may also complain that the fuel gauge does not change in relation to the number of miles driven. This TSB provides instructions to install a modified fuel level float arm assembly.
AFFECTED VEHICLES
2008 Lancer built prior to September 17, 2007.
Hope this helps! I have access to all TSB's and Recalls for any vehicle using my shops computer, so this is a real number. Show your dealer this!
Old Jun 13, 2008 | 05:04 PM
thank you so much guys. after i filled it up again, the gas meter is normal again.
evo9powerr
12
Aug 5, 2014 02:35 PM
Carrier
Lancer Troubleshooting
18
Aug 8, 2007 01:56 PM
AC556k
Nov 18, 2005 12:39 PM
evosevengsr
15
Apr 20, 2004 08:46 AM
AMX
Sep 18, 2003 06:42 PM
