Mitsubishi released a new TSB on no-start issue
Old Jun 12, 2008 | 09:44 AM
bluewaterDEMON's Avatar
This is a new, and different recall from the previous Mitsubishi recall on the no-start/hard-start issue on 08/09 lancers. The first recall was a relay-replacement fix.
The new recall is for a reflash of the Lancer's ECM.
Recall #: TSB-08-13-004
"The no-start/hard-start condition is due to an incorrect parameter in the ECM that closes the Electronic Throttle Valve during start-up and doesn't allow the correct amount of air flow."
I personally still need to take my car into the dealership to have both TSB's performed. Looks like Mitsubishi finally has the entire problem solved.
Old Jun 12, 2008 | 09:51 AM
Anarchy08's Avatar
now all you have to do is try and get them to let works do the reflash and you'll be set.
Old Jun 12, 2008 | 03:01 PM
the_cosworth's Avatar
this was released at least 2 months ago. sorry
Old Jun 12, 2008 | 07:22 PM
Bladed's Avatar
this is the first I've heard of a reflash to fix the startup problem. Thanks for the info
Old Jun 25, 2008 | 12:20 PM
mitsugts's Avatar
got it reflashed at last oil change
Old Mar 31, 2011 | 06:56 PM
s84kam's Avatar
has the reflashed worked? i may need it!
Old Apr 1, 2011 | 09:27 AM
Tapsta's Avatar
I think my lancer is having this isuse as it does not start every time. I do own a 2010 lancer so I'm not sure if I have the 'fixed' tsb.
does the dealership normally charge to have the ecu reflashed?
Old Apr 2, 2011 | 09:45 AM
CamShaft's Avatar
no charge if you have warranty....if you are out of warranty, pay the reprogramming fee.
tsi1991awd
Feb 2, 2010 03:12 PM
desperado-c
Mitsubishi TC-SST Discussion
18
Aug 11, 2008 09:48 AM
ashun22panda
Lancer Troubleshooting
15
Mar 13, 2008 10:42 PM
RussellM
Mar 7, 2008 06:29 AM
