Sagging Lowering Springs?
Old Aug 30, 2003 | 08:53 AM
i_love_spool's Avatar
I got a set of Tein S-Tech Lowering Springs on my car and I have notcied this for a while, but wasn't sure what to do about this......the rear driver side seems to be a half inch lower than the rear passenger side.
I say this because I can get one finger in straight in the rear passenger side well, whereas I can barely get a finger in on the rear driver side well.
Has this happened to anyone else.....anyone know what the problem is?
Old Aug 30, 2003 | 09:06 AM
.L.'s Avatar
.L.
its hard to tell, Tein is a WELL known company that has a good reputation. its common for sagging to occur with cheap/affordable springs. poor quality and construction. you pay for what you get. sometimes its just bad luck, and even if you do go with a good company you just get a bad set of springs. most good places have a "no sag" guarantee though.
Old Aug 30, 2003 | 09:49 AM
02izzel's Avatar
if its that noticable you should call tein. i know they have a one year warranty on a certain about of sag on their s-tech's. hit them up and tell em the situaiton.
Old Aug 30, 2003 | 01:59 PM
RollerPyro's Avatar
Were they professionally installed?
Old Aug 30, 2003 | 02:43 PM
Yes.....
I just went outside and measured the distance from the ground to the bottom of my rear bumper on both sides, here are the measurements:
Driver Side Rear Ride Height - 23 cm or 9.00551 Inches
Passenger Side Rear Ride Height - 25 cm or 9.84 Inches
Essentially, the left side is lower than the right side by almost an Inch....
I wouldn't have a big problem with this if it didn't do anything to my car....but with my big 215-45-17 tires the left tire manages to touch the fender or inner wheel well over small bumps....and that really isn't too safe as my tires could pop or any good for my Proxes because it'll scrape them right up.
I'd love to switch to Coilovers, but I can't really afford the nearly $3000 CDN to buy a set of Tein or JIC Magic Coilovers.
DSMEVOLUTION
17
Nov 22, 2016 08:12 PM
Galaxshiel
Nov 19, 2016 09:58 AM
IonNinja
18
Feb 14, 2008 01:16 PM
DontRevMe
14
Apr 6, 2007 09:57 PM
Babblingsponge
Aug 19, 2003 05:30 PM
