DRL bypass for HID's
Old Apr 7, 2011 | 01:18 PM
  #31
CamShaft's Avatar
Originally Posted by depomps
i dont understand why everyone is buying bypasses and spending so much money... the reason why the drl's still work after you pull the fuse is because theres a second source of power. i got rid of the flicker and the drl's by simply installing a switch after the drl relay. i used a regular toggle switch and grounded the switch. i even installed a switch for my fogs so i can turn them on without having to have my low beams switched to the on position. things u can do by just looking at a wiring diagram....
Some people like to keep their vehicle functioning as normal with the use of the stalk switch to turn on their lights. Yes you can run an entirely new circuit with a switch, but why when you can just install a inline capacitor that will smooth out the voltage sent by the DRL's. I still have an extra set of this wiring harness. Plug and play inline... if anyone wants it, PM me. Cheap.. I paid 25$ will get rid of it for 10+shipping.
I believe i bought them off 02-Lancer-eS but as I posted before, I got a set of them when I returned my HID kit because it crapped out due to flickering...I guess the company had tons of returns so decided to include a inline fix as well....
Would love to get rid of these...unless 02-lancer-eS - you want to buy them back for cheaper than you sell?
Old Apr 7, 2011 | 01:42 PM
  #32
depomps's Avatar
u might be right with the functioning normal part. but still spending more than 10 or 20 dollars for a relay to me is a little pricey. i spent less than 10 dollars on everything. i also wired my fogs so they can turn on independantly as well as getting completely rid of DRLs as a whole. the relay ur selling for 10 is a steal. im surprise no one bought that already from you. good luck selling that. ill probably end up informing some friends around my area about ur sale incase they might be interested. or hopefully thrguy you got them from will take it back. i know hidextra.com sells a pretty good hid kit. my boy has them on his 08 gts and theyre hella dope. he'll probably be the one i tell about your relay
eddielmc
16
Jun 7, 2019 05:56 AM
hispanicpanic
Aug 19, 2015 06:03 AM
jayt27
Aug 14, 2015 06:08 AM
peanutboylancer
Lancer Troubleshooting
Feb 26, 2014 09:14 AM
Alberto521
Nov 9, 2012 11:54 AM
