Leaking Tranny Fluid!!!
Old Dec 13, 2008 | 12:33 AM
sykou's Avatar
Looked under my car today and there was a small puddle of fluid underneath. Looks like its dripping from where the transmission meets the block... Wondering if anyone has had this problem before? I dont think there is a gasket in there right or is there? thanks in advance!!!
Old Dec 13, 2008 | 09:10 AM
Synthrocker's Avatar
Well, you do have 2 seals there, I assume its a automatic?
Got a seal for the block, then the trans, also the torque converter.
Best bet is it get it in the air and check it out, prolly could just be a trans line.
Old Dec 13, 2008 | 10:08 AM
sykou's Avatar
its 5 speed. I redid the oil pan so i know its nothing on the block... Im planning on doing the clutch soon but im just worried about the fluid leaking out before that.....
Old Dec 13, 2008 | 01:40 PM
texaspete108's Avatar
is it constantly leaking out?
Old Dec 13, 2008 | 08:20 PM
sykou's Avatar
Like a small drip. After a week of sitting there was a thin puddle about the size of a legal size envelope... And a small drop coming right out the joint between the block and tranny.
Old Dec 14, 2008 | 06:57 AM
The only way I can think of to find out why it is dripping is to take the transmission off and get a good look inside. Has your trans fluid been changed recently?
Old Dec 14, 2008 | 10:15 AM
sykou's Avatar
Hasnt been changed since i did it at 30k. I got almost 50k on her now. Started leaking after i turbod her tho...
Old Dec 14, 2008 | 01:00 PM
senate6268's Avatar
Is it trans fluid or oil? That will determine if its the input shaft seal or the rear main seal.
Old Dec 14, 2008 | 02:09 PM
sykou's Avatar
To be honest i can.t tell... What should i look for to tell the difference?
Old Dec 14, 2008 | 04:02 PM
senate6268's Avatar
Well if you can't tell the difference between the two then the alternative would be to remove the flywheel inspection plate and see if the fluid is flowing down from inside the bell housing or between the flywheel and block.
Old Dec 15, 2008 | 04:46 PM
mcgarvey's Avatar
Go smell some gear oil out of the bottle and you will have no problem identifying it in the future! In fact you'll learn to hate that smell almost instantly. Engine oil smells like oil, gear oil smells like shat.
Old Dec 15, 2008 | 05:54 PM
Jehuty's Avatar
Exactly what McGarvey said.
Old Dec 15, 2008 | 10:13 PM
senate6268's Avatar
I was skirting around telling him this also since he couldn't tell the difference.
Old Dec 15, 2008 | 10:22 PM
boosted2x2's Avatar
probably your rear main seal
Old Dec 15, 2008 | 10:47 PM
sykou's Avatar
really it smells that bad??? I remember spilling a whole bunch of it on my hands when i changed my tranny fluid but I dont remember it smelling bad. Thats why i can't tell.... I will try and smell some of the tranny fluid i have in the house and compare the smell....
Dallas J
Sep 10, 2019 11:45 AM
RATEDX
Mar 15, 2016 05:42 PM
TommyGunMR
Dec 19, 2009 01:31 PM
VishnuEvoIX2006
Jul 14, 2008 08:51 PM
jrsimon27
Mar 19, 2006 04:45 PM
