3 Little Words/Questions
Old Sep 13, 2003 | 08:42 PM
Biggwill91183's Avatar
Question 3 Little Words/Questions
I have 3 questions, I won a 2003 Mits Lancer OZ-Rally, 1st one is HKS Super AFR, i have it all hooked up to the ECU but there is one blue wire coming from my AFR controller what does it go to, to? My 2nd question is where is my Oil Pump located? i have to put put a blug on it to fit to a -4 90 deg. Fitting connected to metal fiber hose that is connected to another 90 deg. -4 fitting to the top of my turbo, do u know a good way to put this plug in my oil pump? My finnal question is at the bottom of my turbo there is an oil return hose now i think i need to put a bung or a bunt in my oil pan and connect it to my oil return hose, any suggestions?
Old Sep 13, 2003 | 08:54 PM
Sorry i own one i did not win one
Old Sep 13, 2003 | 09:06 PM
4Gaijin63's Avatar
dude its really hard to understand what you're saying. if you want some good help i'd call rmr or rrm
Old Sep 13, 2003 | 10:46 PM
sorry for the mis'understandment, but all i need to know where is the oil pump located on the us lancer, and if anyone knows about HKS's Super AFR (Air/Fuel/Ratio) Controller. and know what they hooked up the blue wire to then i would be most greatfull. thnx
Old Sep 13, 2003 | 10:58 PM
ozlancer0z's Avatar
i think you should just call RMR or RRM also. i think they'd be happy to help. (OT) are you new to the US?
Old Sep 13, 2003 | 11:07 PM
Alchemist's Avatar
Do you already have a wire hooked up to the Throttle positioning sensor (TPS) wire? The eManage doesn't tell you to do this but it's vital- I don't know if the HK$ AFR needs to measure this, but that's about all I got for ya
if you think that might be it, look for Rhyzin's "SAFC install" post in the US Lancer how-to/installs section- he has a pretty picture with all the basic wires labeled.
Old Sep 14, 2003 | 05:04 PM
yes i have one hooked up to it, i think it might be a wire to the bypass wire of the yellow wire and orange wire that comes from the ARR. My buddy siad it might also be a 2nd or backup ground, the wire i have nothing to hook to, HKS installment guide doesent say anything about that wire..... it might be hooked up right and there is an extra wire. I'm not suposed to hook up anything to that O2 Sensor am i? its labled in that picture i got off here, showing where the ECU was and what wires to cut
Old Sep 15, 2003 | 08:50 PM
how do i delete a Topic??
Old Sep 15, 2003 | 08:56 PM
HobieKopek's Avatar
You don't.
SKILMATIC
Feb 27, 2014 08:26 AM
Archlegan
Lancer Aftermarket Forced Induction Tech
Nov 26, 2013 05:35 PM
slatermvp
Apr 19, 2011 07:58 PM
kungfugirl
41
Aug 24, 2008 08:20 PM
Sicktght311
Nov 7, 2006 10:20 AM
