Low Tire Pressure
Old Jan 17, 2009 | 05:14 PM
deanlwvu's Avatar
Low Tire Pressure
Does anybody get the "low tire pressure" warning in very cold weather? When I start my car in the mornings in below 25F temp, i get the "low tire pressure" warning. Every time i check it, all 4 tires are fine.
Old Jan 17, 2009 | 05:51 PM
krnkimchi702's Avatar
warm air expands.. thats why when your tires are warmed up, the warning goes away
Old Jan 17, 2009 | 05:52 PM
MasterAK's Avatar
what's the pressure when the car is cold? I usually keep my tires inflated a couple psi above the recommended pressure so even when it's very cold it doesn't drop low enough to show a warning. but you're supposed to adjust the pressure according to the season.
Old Jan 18, 2009 | 09:52 AM
deanlwvu's Avatar
i'm saying that when i check it before i run the car, they're fine. maybe i'll add a few pounds.
Old Jan 18, 2009 | 03:40 PM
nj_08_gts's Avatar
35 PSI seems to be the magic number...no matter how cold it is outside, you'll never get the TPS warning.
Old Jan 18, 2009 | 04:08 PM
MasterAK's Avatar
just make sure to check them again from time to time especially when it starts getting warmer.
Old Jan 22, 2009 | 04:09 PM
smokem22's Avatar
i have had this problem too in both hot and cold weather on more than one tire. Neither tire had any holes or anything when the dealership checked it all they could say was continue to monitor it. i said screw that got some of that green goop from autozone havent had a problem since and its 2 weeks later
Old Jan 22, 2009 | 06:43 PM
Stuntfly02's Avatar
That green goop is the worst thing you can put inside of your tires. Enjoy paying extra for having it cleaned out at some tire shops. Besides that stuff is meant as a temporary fix. The most probable reason you are losing pressure is a bad seal on the bead of the tire. Have them demount and remount the tire...and make them check the bead of the tire and make sure there is no damage.
Old Jan 31, 2009 | 10:01 AM
dyno's Avatar
Yes, colder temperatures cause you to lose a few PSI -- setting off the TPMS. Also you might have a faulty rim or seal at the bead. I took off the stockers set at 35 psi and have been sitting in my garage while I'm rocking steelies with winter tires. One of my stock tires is completely flat only after 2 months. Guess I will have to get that checked come spring time. Alloy rims are notorious for leaking due to their porous structure.
Old Feb 11, 2009 | 05:55 AM
tranceguy420's Avatar
Si senor, i have this problem as well, i asked my service manager about this and he says the cold weather will cause this if your tire is even a little low, and still may come on if you are at 32 psi at 40 degrees. Air contracts at cold temperatures, and expands at warmer. Fill your tires to slightly above 32 and that should solve the problem in the winter. As you know, lower tire pressure will reduce your gas mileage.
Old Feb 24, 2009 | 11:24 PM
lancerarmstrong's Avatar
check your tires for nails, i've only had mine since sept. and i've already had 2 screws in der
Old Mar 13, 2009 | 05:00 AM
ejlancer's Avatar
nitrogen helps a little bit also i put about 37 psi in min
EndlessRed
Nov 7, 2009 09:26 PM
HR2L
16
Oct 19, 2009 03:30 AM
itzsteven
Dec 14, 2008 06:26 AM
LancerGirl08
Canadian Forum
32
Dec 9, 2008 04:49 PM
Highwind
14
Jul 7, 2008 03:59 PM
