Help! Lumpy idle & misfires under high load
Set up: Turboed with FMU
I'm throwing codes p0171 - System To Lean (Bank 1) & P0135 - Front O2 Sensor Heater Circuit Failure
I've replaced my first O2 sensor thinking that may be it but no go...
Its been a while since the conditions started but its like the topic says.
The idle bounces from 600-800 while in park and only in park.
As far as misfires, there are none in 1st WOT, in second WOT the misfires start.
I'm pretty sure the two issues are related but I can't find the root.
From reading other threads I think it may be a vacume line but I only touched very few. Those were on the side of the IM to connect my FMU and on the front of the IM to connect a vacum for my BOV. I don't think I messed with anything else.
I'm stumped on what to do next. Could you guys help me out?
Thanks!
Thanks!
Do you have a wideband? Do you know if the FMU is still working correctly? Also check the vacuum hose for the fpr. Mine had similar issues and I found a small hole in the vac line...
If its misfiring under WOT it'll give a CEL for that. It's p0401, p0402, etc, the last number being the cylinder.
What spark plugs are you using? Along with injectors and engine management?
Got the codes today. Im still throwing p0171 - System To Lean (Bank 1) and I have a misfire on Cylinder 3.
I've been a little suspect of my FMU. It never gave me any reason to doubt it but I just don't trust it. When I get some time (probly Thursday ) I'm going to check the lines on it and pull plug #3. I'll probly also change back to my stockspark wires since a squirrel decided to "taste" my Magnecores a while back.
I can't help but thinking I don't have a vacume hose set up right or a hole in one but that would be too easy. Where you you have the vacume for your BOV tapped to?
No Wideband BTW...
No Wideband BTW...
my car is a n/a still and just intake and echaust i have the same problem my car has 112k on it and stock injectors i did an Oscilloscope test and injector number 3 is failing. and it was getting pretty bad and i had the same codes i replaced the front o2 and it helped a little but still misfired really bad i would check your injector's if you could it might and if they good, the coils and wires are good,and fuel i would do a noid test on it to make sure your injector's are getting the signal to fire good luck with it.
Pulled Codes again tonight... No more P0175 Cool But I'm still getting bank 1 too lean.
I pulled second and third plugs...
#2 Top
#3 Top
I went ahead and bought some new pluds and ran into another problem. They didnt stock NGK BR7E's so I ended up getting BKR5E-11 V-powers. Those are supposed to be cold plugs like the 7E's.
Would those be a safe replacement for the 7E's?
More info on the problem though, Now it seems as when I get into boost it's missfiring. When I pass boost threshold, I can expect them.
Would a bad coilpack on cyl #2 effect the spark on #3?
#2 Top
#3 Top
No the wires are not in great condition. A while ago a squirrel chewed on both of my wires but they ran fine. I always was looking to replace them but since they never flubbed up it wasnt high on the "to-do".
But I'm changing them back to stock right now and I just happened to find 2 extra BR7E's just laying around from the build last year so I'm putting those in now. I'll see whaat happends...
Those other plugs the BKR5E-11 are supposed to be one-step colder plugs but I've never heard anyone mention them so I was kinda unsure. I'll keep those NGK BKR6EIX's in mind though.
Teal2nnr
Feb 25, 2017 10:55 PM
michaelanjolo
Feb 25, 2016 11:44 AM
comatose721
Lancer Troubleshooting
15
Jan 11, 2008 10:28 AM
