issues
Old Aug 3, 2009 | 03:05 PM
sidewayzz's Avatar
issues
im having problems tracking down a weird ticking noise in my 02 es.
i thought it was an exhaust leak but ive check every connection and nothing seems to be leaking.
it sounds like a valve tapping like crazy but only when im above like 2700 rpm so im pretty sure its not a valve.
im stumped and need all the help i can get its driving me frickin crazy.
edit: i forgot to mention it only make this noise when im driving when i just rev it it does it quietly
Old Aug 3, 2009 | 03:52 PM
imalancerman's Avatar
Mitsus make alot of valvetrain noise. Usually its something like a dirty lifter as our lifters can get dirty very easily.
Old Aug 3, 2009 | 04:29 PM
sidewayzz's Avatar
thanks for the reply. im gonna try running some seafoam through it you think that'll help?
Old Aug 3, 2009 | 04:33 PM
*02Lancer*'s Avatar
I had a noise kinda like that with old engine. What do you use? And are you in need of an oil change because after you run seafoam you need to change your oil. But seafoam did help with my noise. But changing to mobile 1 5w-30 was the trick for my engine. No noise almost at all. Same with new motor no noise yet anyway.
Old Aug 3, 2009 | 04:50 PM
Seafoam can help yes, but only if you put it in the oil. And you dont need to change the oil till recommended timing when you just put it in the oil. If you run it through the intake, the so called "seafoam treatment", you are supposed to change your oil right after. Also, check your oil levels, you'll develop random ticks when the level is low.
Old Aug 3, 2009 | 09:27 PM
sidewayzz's Avatar
thanks for the replys.
my oil is full and im not in need of a change for another 500 miles.
i use castrol syntech 5-w30
im gonna try out the seafoam and see if that helps tommorow im hopin for the best i cant take that frickin ticking haha
Old Aug 4, 2009 | 12:00 PM
sidewayzz's Avatar
seafoam didnt stop the ticking smoothed my idle though haha
any other suggestions?
Old Aug 4, 2009 | 12:07 PM
Your gonna have to dissassemble the head and clean the lifters. Very easy project, no need to drain oil or remove the head from the car. You just take the valve cover off, take off the rocker assembly, and then pull out the lifters and watch this. http://www.youtube.com/watch?v=gKX2pYVO0Ak . I know it isnt our car, but its a mitsu and the procedure works the same. Its really not a difficult procedure. PM me for pics if you want of the disassembled head if you want an idea of how to do it. Just saying.
Old Aug 5, 2009 | 11:34 AM
sidewayzz's Avatar
ok sounds like im gonna need to make some time in my schedule haha.
how long do you think it should take me?
Mark_L
Dec 29, 2014 01:13 PM
alex the great
Mar 23, 2013 09:48 PM
123kid
Mar 8, 2013 07:02 AM
nonojoe66
Oct 27, 2009 10:47 PM
