Timing belt repair
Old Aug 20, 2009 | 01:54 AM
Lancer XI1's Avatar
Timing belt repair
Is It Very Expensive To replace the timing belt? I m just going to replace the water pump too since their in there if its not too pricy
Old Aug 20, 2009 | 07:57 AM
JRR's Avatar
JRR
for the timing belt you are looking at about 50 bux if you get it from a parts store. expect to pay about 70+ from the dealer. as for the water pump 100 new / 80 remanufactured and about a couple hours of time. not too bad compared to some vehicles.
Old Aug 20, 2009 | 12:06 PM
Lancer XI1's Avatar
how bout on average repair cost cause I was looking around and i ve seen anywhere from $300 to $900.
Old Aug 20, 2009 | 12:21 PM
Z_Lancer_Man's Avatar
Timing belt repairs usually cost around $500 in my experience. I would just pick a service manual and do it yourself! Think of all the mods you could buy (or other bills you could pay) with the savings!
Old Aug 20, 2009 | 03:54 PM
JRR's Avatar
JRR
when i did mine it wasnt that hard. just make sure things line up to where they should be.
Old Aug 21, 2009 | 01:49 AM
03lances's Avatar
Little trick I do for timing belts is after you the get engine to TDC take some white paint and put a solid mark over the camgear and belt, and crank gear and belt, then take those marks from your old belt and tranfer them to your new belt and just line the marks on the new belt up with the marks on the cam and crank and viola your golden, works awesome and saves me LOTS of time everytime
Old Aug 21, 2009 | 10:09 AM
JRR's Avatar
JRR
Originally Posted by 03lances
little trick i do for timing belts is after you the get engine to tdc take some white paint and put a solid mark over the camgear and belt, and crank gear and belt, then take those marks from your old belt and tranfer them to your new belt and just line the marks on the new belt up with the marks on the cam and crank and viola your golden, works awesome and saves me lots of time everytime
^+1
Old Aug 21, 2009 | 10:14 AM
kwanza's Avatar
I would also consider :balance shaft belt, timing belt tensioner pulley, timing belt idler pulley, balance shaft tensioner pulley, hydraulic tensioner.
Old Aug 22, 2009 | 09:51 PM
LancerEVA06's Avatar
There is no balance shaft on the 4G94. Also no idler pulley. Starting at 12:00 it goes; Cam sprocket, Water pump sprocket, crank sprocket, tensioner pulley. The Tensioner is spring loaded.
To have a dealer do the water pump, tensioner, and belt, you're looking at about $550 (if your dealer is using matrix pricing for parts, less if they are not.)
Like everyone said, the timing belt on this car is simple. From start to finish, I can do them in about 2 hours and basic hand tools.
Old Aug 22, 2009 | 11:03 PM
03lances's Avatar
+1 nuff said... it really is very easy expecially if you use the white marks as I suggested
lbwilliams44
Sep 20, 2013 03:32 PM
OC
Apr 22, 2013 10:32 PM
evoboy2012
Mar 2, 2012 09:15 PM
tim85851
11
Dec 10, 2011 09:42 PM
Hcaruso4
29
Sep 26, 2007 04:23 AM
