f*%$#!@ing squeek!
Old Oct 17, 2003 | 05:02 PM
02izzel's Avatar
Unhappy f*%$#!@ing squeek!
this is the last place i wanted to opst on this site..but i have a lil problem...
there a squeek comming from my engine area. last night it was only whn i hit a bump or something..leading me to believe its my struts or springs..or i didnt put my k bar on tight enough. NOW its starting to squeek when i turn. not good. and its not my tires rubbing because i already fixed that problem. it souinds like its comming from the passenger side..but i dunno. its hard to tell while driving.
BTW i do have progress springs.
suggestions or anyhting would help. thanks!!
- ian
Old Oct 17, 2003 | 05:04 PM
Sonantoni's Avatar
maybe it's something with your power steering???I will check it out tonight @ sonic...
Old Oct 17, 2003 | 05:09 PM
2002OZ's Avatar
is it a squeek or is it a rattle? I have the progress srpings and i get a rattle noise.
Old Oct 17, 2003 | 05:27 PM
uranium9v's Avatar
Could it be your brakes? I had a very similar squeek and it turned out to be my brakes.
Old Oct 17, 2003 | 05:34 PM
ozlancer0z's Avatar
did you hit the bump pretty hard?
Old Oct 17, 2003 | 06:05 PM
02izzel's Avatar
no to all of the above. its not while im braking and turning, just turning. and i dont drive crazy over bumps. my car is my baby.
i dont htink its power steering. i heard it squeeking on the acces road going home last night on a relativly straight road.
Old Oct 17, 2003 | 06:09 PM
uranium9v's Avatar
When it was my brakes, it only made the noise when I WASN"T braking. got louder when I turned and I could make it stop squeaking if I jerked the car the other direction.
Old Oct 17, 2003 | 08:33 PM
02izzel's Avatar
hmm..might be the brakes. but .. last night i would go ove a slight bump and hear a slight squeek. and now small bumps or turning it makes a noise..so i dunno
what did you have to do U9V. replace anything?
Old Oct 17, 2003 | 08:54 PM
02izzel's Avatar
ok. im going to try to describe the noise i hear..its like when steel is being bent. its kinda a grind..but more of a squeek.
Old Oct 17, 2003 | 09:15 PM
swhskenr's Avatar
is ur ac on?
Old Oct 17, 2003 | 09:31 PM
02izzel's Avatar
nope. i BARELY use it, even in this texas heat.
Old Oct 18, 2003 | 08:40 AM
02izzel's Avatar
hmm..i forgot how boring life was whn you dont have a car.
im too afraid to drive it to a shop. i dont want my wheel flyin off when im on the highway.
Old Oct 18, 2003 | 10:25 AM
02izzel's Avatar
WELL, i got a wrench and a rubber mallet and tightned all the bolts that hold the K-bar to the top of the struts..and it worked. How long it wont squeek is the real question.
Old Oct 18, 2003 | 07:02 PM
02izzel's Avatar
ok. that didnt last too long. now it only squeeks when i turn left. any help from you grease monkeys?!?!
Qutenoypi
27
Jun 7, 2010 07:38 PM
Xearo
May 13, 2009 08:28 PM
Pure Playaer
26
Dec 25, 2006 10:11 PM
en1gma19
Feb 19, 2005 02:14 PM
josh930
Aug 1, 2004 07:48 PM
