Brake Light
Old Oct 5, 2009 | 06:40 AM
Jehuty's Avatar
Brake Light
i have a problem with my brake light, I put down the emergency brake but the light is staying on no matter what. When I accelerate it will turn off, but then it will come back on.
Like this:
Any assistance will be great.
Thanks guys
Old Oct 5, 2009 | 07:40 AM
link62's Avatar
could be cause by the lil switch on the e brake or something electrical
Old Oct 5, 2009 | 07:45 AM
Jehuty's Avatar
any ideas on what to check and/or replace?
Old Oct 5, 2009 | 07:58 AM
link62's Avatar
not sure off the top of my head try taking off ur arm rest and when u take the e brake off see if pushes the switch if the light doesnt turn off take a look at it thats the only thing i can think of
Old Oct 5, 2009 | 08:03 AM
rcheung's Avatar
Check your brake fluid level. 99.9% of the time, that is the issue.
Old Oct 5, 2009 | 08:26 AM
Jehuty's Avatar
I'll have to check this out
Oh wow, I've never heard this. So if it's too low the brake light will turn on, seriously?
Old Oct 5, 2009 | 08:32 AM
rcheung's Avatar
The ebrake and brake fluid level indicator make the same light go off in most cars. I have personally never seen an ebrake switch go bad but have always had the issue of the fluid being low when the brake light wont go off in every car i've owned.
Old Oct 5, 2009 | 09:38 AM
Jehuty's Avatar
Believe it or not this is the very first time I have heard of this. Thanks for the heads up, i'll be sure to check out the level today. It would make sense on why the light goes off when I accelerate (the fluid could move back from the g's) and then turn back on right after.
Old Oct 5, 2009 | 09:47 AM
rcheung's Avatar
The slosh of the fluid can make the light go on and off. Let us know if this was indeed the issue.
Old Oct 5, 2009 | 12:21 PM
Jehuty's Avatar
I'll check...but I would assume that it would need to be below the "min" level in order for that to be the issue. I wasn't able to check it during my lunch break, so I'm not too sure.
Old Oct 5, 2009 | 02:23 PM
ThunderOZ's Avatar
Did you check the little connector under the center console armrest?
Old Oct 6, 2009 | 03:41 AM
Jehuty's Avatar
no sir, that will have to be done on the weekend. I leave home too early and get home a little late
Old Oct 7, 2009 | 03:15 AM
Jehuty's Avatar
Ridiculous...it was the brake fluid...thanks guys
Old Oct 7, 2009 | 12:54 PM
rcheung's Avatar
So now that means your pads are low or you have a leak in the hydraulic system. You might want to check that out as well.
Old Oct 7, 2009 | 01:06 PM
ssg_petty_210's Avatar
well check your brake. Im in iraq, and my wife told me that the brake light stayed on even with the e brake down. So i said check the fluid, and if it needs refilling then do it. She did and now the light is gone. She had me worried for a minute. Being in iraq is not the time you wanna hear about your car having problems lol
