Input needed - bucking
Old Nov 10, 2003 | 01:35 PM
JVlancer's Avatar
----Help input needed-----
I got out of work today, warmed my car up and when i went to tap the gas it shot up to 2.5k rpm then just died. I was like wtf is going on, then when i got off the highway i was barely gassin 3rd gear and then it started slightly bucking.
Im wondering weather its the $hitty gas from sheetz, but i put 89 in all the time, or clogged injectors, or possibly clogged fuel filter
Then when i get to the light it keeps missing idle, every time bouncing to 800-300 rpm then i tap the gas and it hesitates for a milisecond, then finally jacks up the rpms.
ANY Input will be greatly appreciated
Old Nov 10, 2003 | 01:40 PM
LancerO-Z's Avatar
Could be bad gas. Sheetz gas defintely isn't the best. I am originally from WV, and that stuff always made my truck run like crap. I'd say next time you gas up, dump in some good injector cleaner, and get some Chevron or Exxon 93 Octane. If that doesn't do it, then it could be your fuel filter, could be a lot of things. It's really hard to say, but definitely dump in some good injector cleaner. It can't hurt to try that. Hope this helps.
Old Nov 10, 2003 | 01:44 PM
JVlancer's Avatar
heh.. already did that soon as I felt that crap I went to the parts store and dumped a bottle of it in.. gonna gas up with 93 next tank.. too bad dont have BP's around here.
Old Nov 10, 2003 | 04:26 PM
pjal84's Avatar
I don't understand how bad gas is the issue. The car doesn't require anything more than 87 unless you have an ECU reflash or you're boosting. How much fuel did you have in the tank when all this occured? Could've been a starvation issue.
Old Nov 11, 2003 | 06:32 AM
JVlancer's Avatar
3/4 full, well after I dumped that injector cleaner in seemed to fixed the problem, getting new injectors with zlancers kit when i pick it up next week so I think ill be ok.
Old Nov 11, 2003 | 06:50 AM
HobieKopek's Avatar
Well, bad gas is different than low octane. I doubt your injectors are gummed up, but if it makes you feel better...
Bucking usually has to do with accel fuel curves. The stock ECU actually has some pretty damn good ones, but it is possible to overwhelm it if you get on it too hard from very low/no throttle or if . It seems unlikely that this was the case though. Try buying your fuel from a different place next time, but you don't really need a higher octane mix.
Oh and I'm changing the name of the thread to better explain the subject.
Old Nov 13, 2003 | 10:33 AM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
Last time I had a car start bucking on me (was a trans am) it was the ECU dying. But the reason for that was when the ECU dies, the fuel runs super rich. I doubt your ecu died this early (unless you were pouring out black smoke at the end of that driving session), but maybe the sensor was getting bad messages. This could be a number of things (vacuum lines, intake, electrical short). Just out of curiosity, did the "better" gas fix the problem?
Old Nov 13, 2003 | 10:44 AM
JVlancer's Avatar
hopefully problem fixed just drove 120 mi each way to philly yesterday after i changed my oil.. dont seem to have buck/idle problems any more...
Old Nov 13, 2003 | 10:45 AM
JVlancer's Avatar
btw.. i think the
"better gas" did fix the problem #1 reccomendation the reason why sheets gas is so cheap is cuz there must be water in it .. lol.. pos gas
Old Nov 13, 2003 | 10:54 AM
Sailorgoon's Avatar
If this happens to anyone else, start by checking your gas cap. Make sure it's good and tight, or the pump could have trouble pulling fuel from the tank. Even the manual says something about that, I think.
Old Nov 13, 2003 | 11:08 AM
Moderator
Bomb Squad Unit #02
Never thought about that, but it does make sense. No cap means no pressure and less suction. Thanks Sailorgoon!
Old Nov 14, 2003 | 06:54 AM
HobieKopek's Avatar
Yeah, the OBDII system is very sensitive. Usually it'll toss a CEL after a little driving though.
Masterr
Dec 6, 2016 11:17 PM
emerica5571
AEM EMS
Oct 18, 2015 07:12 AM
SR Concepts
Apr 26, 2015 10:15 PM
matrho2792
Aug 23, 2014 02:45 PM
silvrevo
Apr 13, 2004 10:14 AM
