Engine noise after timing belt change...
Old May 17, 2010 | 07:23 AM
simplecomplex's Avatar
I drive an 03 ES 2.0L & I just changed my timing belt & water pump over the weekend and everything seemed to go well. After I finished, I started it up and it sounded fine. But once I started driving it the engine makes a kind of whining noise. It's definitely coming from the area of the engine where the timing belt is. The timing was dead on, the water pump was installed without a problem. Does anyone have an idea of what the whining could be? A friend who's a mechanic said it's probably that the timing belt tension is too high. If that is the case, is there a way to loosen the tension without taking off the covers & motor mount on the 03? Any thoughts?
Old May 17, 2010 | 07:38 AM
dreyfus14's Avatar
The whine is definitely from the Timing belt being too tight! You will have to take the covers and mount back off. Whe nthe timing belt is too tight it will give off a sense of having a supercharger and get louder as the RPM's get higher.
Old May 17, 2010 | 07:45 AM
Thanks for the input, dang I was hoping to avoid having to take all those parts off.
Old May 17, 2010 | 08:20 AM
eusgen's Avatar
Do it right the first time and you don't have to do things over again. (Had to take a door panel off 3 times because something wasn't right )
Old May 17, 2010 | 08:43 AM
Yea, your right about that man.
Old May 19, 2010 | 05:39 AM
Just as an update to anyone reading, the whining was definitely because of an overtightened timing belt. Yesterday, I backed the pulley off just a touch (I slid the pulley in the opposite direction of the water pump about 3/8 of an inch) and reassembled everything. The noise was gone and actually the engine sounds better than before. Thankfully I didn't throw a bearing in the water pump or mess anything up.
Old May 19, 2010 | 06:59 AM
dreyfus14's Avatar
Awesome, good news! Learn from our mistakes right?
Old May 20, 2010 | 09:09 AM
Yep, and I won't have to change the belt or water pump for the next 60,000 miles. I'm glad that's over.
orion4096
35
Jan 25, 2016 03:37 PM
evo_k
Pacific Northwest
18
Jan 10, 2015 07:56 PM
MnchMnchV84Lnch
Jun 22, 2014 10:46 PM
evo_k
May 18, 2012 04:43 PM
fuzzychi
22
Jan 20, 2010 08:58 PM
