HID's and DRL's
i dont understand why everyone is buying bypasses and spending so much money... the reason why the drl's still work after you pull the fuse is because theres a second source of power. i got rid of the flicker and the drl's by simply installing a switch after the drl relay. i used a regular toggle switch and grounded the switch. i even installed a switch for my fogs so i can turn them on without having to have my low beams switched to the on position. things u can do by just looking at a wiring diagram....
u might be right with the functioning normal part. but still spending more than 10 or 20 dollars for a relay to me is a little pricey. i spent less than 10 dollars on everything. i also wired my fogs so they can turn on independantly as well as getting completely rid of DRLs as a whole. the relay ur selling for 10 is a steal. im surprise no one bought that already from you. good luck selling that. ill probably end up informing some friends around my area about ur sale incase they might be interested.
Alberto521
Nov 9, 2012 11:54 AM
