Weird Noise Upon Trying to Change Rotors
Old Mar 6, 2011 | 07:59 PM
sioux90's Avatar
I tried to replace my old rotors with new Brembo blank rotors and upon trying to fit it on, the pattern was different (probably 2003 LS model, anyone want a pair?). I put everything together. Works fine, stopping is the same. However, upon start-up (first 3-5 minutes) I get a strange noise when braking (especially low speeds), like a fluid noise. I checked the fluid level, it is maybe 25 ml over the max line (for some reason, was like 25 ml below when I last checked before chaning rotors). The noise is a deep noise (that sounds like fluid). It is coming from the right wheel (the one I tried to change the rotor on). Any help?
Old Mar 7, 2011 | 12:04 PM
mci2727's Avatar
Did you compress the caliper piston?
If so did you take the cap off the master cylinder before you did?
Old Mar 7, 2011 | 12:43 PM
blaze_125's Avatar
Are you thinking "air bubble"? That would be my initial guess.
Old Mar 7, 2011 | 05:23 PM
cfdfireman1's Avatar
What the hell is a "fluid noise" do you mean like rain or waves maybe an open water faucet?
Old Mar 8, 2011 | 12:08 AM
mci2727's Avatar
Yeah, I'm thinking maybe he didn't take the cap off and when he compressed the piston the pressure had to go somewhere.
Pulling air into the system.
But I don't know...
The fluid level raising is something I've never heard of.
Old Mar 8, 2011 | 07:41 AM
sioux90's Avatar
I am thinking there are bubbles in the brake line, but I never heard how they sound like, so I can't compare. I did not take the cap off when compressing the caliper. I will be redoing them today with Duralast ones, will post updates.
Old Mar 8, 2011 | 02:32 PM
mci2727's Avatar
You may wanna just try bleeding your brakes.
Prob. fix them.
jackfrog
20
Aug 22, 2014 06:49 PM
OG
17
Jul 13, 2012 10:34 PM
DrivelineSales
Evo 'For Sale' Suspension / Brakes / Handling
58
Nov 24, 2008 12:30 PM
gsx95
11
May 9, 2006 08:56 PM
93civEJ1
Sep 13, 2005 10:34 AM
