Mits Lancer GTS / Vibration
Old Apr 10, 2011 | 10:00 PM
brianpommy's Avatar
Gday Guys, I need some advice please.
I have a 2009 Mitsubishi Lancer GTS, 2.4 L Manual Transmission. I am in Dubai. This car has been in an accident, to the front LHS/drivers side. which has been repaired.
I am experiencing bad vibration when accelerating, also a clunking noise when I turn to the right. I have had the tires balanced, wheel alignment and overhauled both of the axles bearings and tie rods. One mechanic has said it could be the bearings in the gearbox, where the axle fits.
Any suggestions? Parts are a little difficult to come by here in Dubai, as it is a US spec model.
Cheers
Old Apr 11, 2011 | 10:31 AM
evo_soul's Avatar
Cheers
This is tricky. But to narrow this down abit.
1) drive with another set of tires as a test to completely eliminate the possibility of the tires / rim
2) Does the engine vibrate on idling? What happens when you rev the engine in neutral (not in gear)
Old Apr 12, 2011 | 09:25 PM
brianpommy's Avatar
Thanks for reply...
When i rev the engine in neutral there is no vibration, or just with idle.
I had a Turning shop here do an overhaul of the LHS Axle which initially made a big improvement, but then deteriorated after a day or so. I wonder if the CV joint is still defective and maybe I should get a second hand Axle shaft complete? Maybe the chassis was not repaired 100% correct after the accident?
I will try and rotate the tires and see if this improves things..
Old Apr 13, 2011 | 04:58 AM
Belgaram's Avatar
I had a similar issue with vibration and it turned out to be a slightly loose bolt in the front passenger side caliper. The back bolt that bolts the caliper behind the rotor.
Old Apr 14, 2011 | 09:21 PM
CamShaft's Avatar
i would say it is the axle, as you said you have a clunking noise when turning. From what you have described, i would say its 99% the axle
Evo9_Dubai
Dec 22, 2015 03:23 AM
Evo9_Dubai
For Sale - Part Outs
Jun 28, 2015 08:02 AM
seiya
Lancer Engine Management / Tuning Forums
Jul 26, 2012 09:43 AM
EvoVIII03
18
Sep 19, 2010 02:45 PM
dxbevo9
Middle East Forum
Jan 29, 2008 03:56 PM
