Front solid motor mount / Noise problems.
Old May 3, 2011 | 09:10 PM
syntax182's Avatar
So I put some 3m windo weld in my front mounts a few weeks ago.
Love it, but the problem is whenever I launch or just quick acceleration from first gear, I get this noise that sounds like plastic hitting each other really fast, almost like a machine gun but a little slower. This only happens from first gear when accelerating, all other gears do not make this noise. Sounds like its coming from near the pedals.
Anyone have this problem before, or how to isolate where this noise is coming from so I can fix it?
Old May 9, 2011 | 10:46 PM
mci2727's Avatar
I don't have this issue.
I would say if it is plastic hitting then you'll be able to tell soon enough where it leaves marks.
Could it be your fans?
Old May 10, 2011 | 10:04 AM
syntax182's Avatar
Thanks man for replaying man, I figured it out.
When I put on the RMR Lip 2, I didn't use any screws or clips to secure it to the bumper under the wheel wells, so when I accererate it causes more vibration/rattling from when it was stock.
Old May 10, 2011 | 06:09 PM
mci2727's Avatar
Good to hear.
va1k0s
May 31, 2016 10:36 AM
va1k0s
Mitsubishi TC-SST Discussion
May 19, 2016 07:57 AM
alfonso_meneses
Jul 25, 2015 09:59 AM
ahendrickson
May 10, 2011 06:56 PM
