ECU question.
Old May 29, 2011 | 02:42 PM
Rummy636's Avatar
ECU question.
My car all of a sudden shut off ttoday. Found vehicle had no spark for cylinder 2 and 3 coil. Checked both coils by swapping.Found both coils worked when using connector for cylinder 1 and 4 . checked the voltage output to coils. Found when attempting to start, found very low voltage compared to connection at other coil for trigger. Trigger voltage at 1 & 4 coil at 6.3 volts and .78 mV on coil 2 & 3 trigger. Tested connection from ECU to coil for trigger. Found 0.02 ohms. Im looking at needing a new ECU. So i got three questions. One: Is this a fair diagnosis of the problem? Second: the vehicle looks to not have an immobilizer ring, so can i order a reman or used ECU as long as it has the proper ECU code? Code: MR578519 Third: Is there any special coding/VIN writing that is needed if installing a reman or used ECU?
Old May 29, 2011 | 06:24 PM
lil' jeff's Avatar
hey brother not too smart on the electronics on these cars but if it comes down to you needing one i got one, it had 110,000 miles on it and worked when pulled. hopefully its just something small.
Old May 29, 2011 | 10:20 PM
mci2727's Avatar
As far as the diagnosis goes I don't know at all man.
Yes you can get a used or reman ecu.
No immobilizer on the 02 Lancer, and the rom code ("ecu code") doesn't matter as long as it's out of a comp. Lancer.
Now if you want to flash the ecu down the road then you should find a rom code that has a definition file written for it.
But I don't guess that's a issue here.
Old May 30, 2011 | 09:49 AM
Rummy636's Avatar
Thanks for the info guys. I was pretty sure it was a switch and go but wanted to make sure before i jumped at it. Yeah no ECU programming here. Got another Mitsu for the toying around.
mrfred
Dec 31, 2023 08:49 AM
joedr
Nov 12, 2022 08:04 PM
dudemeister
Lancer Troubleshooting
Jan 18, 2011 10:51 PM
lp_ceo
Sep 2, 2010 05:09 PM
EVOclub4
Nov 13, 2007 06:41 PM
