Clutch
Old Mar 11, 2010 | 10:24 AM
blaze_125's Avatar
Originally Posted by Twitch377
or is my input shaft bearing going bad and allowing oil through the bearing and onto the clutch disk?
That could very well be it.
If your car still drives, it'd be easy to know if your clutch got soaked.
If the clutch slips alot, it probably is. If the clutch doesn't slip yet you still get the smell, trans fluid might be leaking out somewhere and getting onto hot engine parts causing it to fume/smoke and smell really bad.
To know if your clutch slip is also kind of easy.
Drive the car in 4th, or 5th and go pedal to the metal. If the tach needle goes up faster than the speedo needle, your clutch is more than likely slipping.
edit:
sorry, I just noticed your PM and the date of your post. I don't really come here very often anymore...
blancoloco
Jan 30, 2017 08:28 AM
mexigun
Automotosports - Illinois
14
Oct 24, 2010 08:08 AM
domantas
Jul 4, 2010 11:42 PM
boczo777
Jun 16, 2010 06:05 AM
ChrisEVO
31
Jan 12, 2003 08:32 AM
