Clutch
Old Jan 16, 2004 | 07:08 PM
deltron79's Avatar
Clutch
Just wondering, but I think it is time for me to change my clutch. I just want to know how to tell when it's due for a new one?
Old Jan 16, 2004 | 09:28 PM
Probleminfected's Avatar
slipping, chattering, hard shifting, grinding gears, noises
you'll know, you'll either hear it or feel it.
Old Jan 16, 2004 | 11:45 PM
deltron79's Avatar
not really experiencing hard shifting or grinding, yet slipping is ocassional and chatteringwhen cold occurs
Old Jan 16, 2004 | 11:51 PM
coal's Avatar
Go get that replaced. If its slippin its time man. How many miles you got on that clutch. It could be oil getting on the clutch through the seal make sure you check for that. I had a car feel like the clutch was going and the tranny was leaking oil onto the clutch. Just keep your eyes open.
Old Jan 17, 2004 | 04:09 AM
SirK's Avatar
mmm. mine has gone under warranty 30,000kms.
Old Jan 17, 2004 | 08:04 AM
deltron79's Avatar
i have almost 40k on it... this coming month i will have fundage for it...now i am babyin the thing
Old Jan 30, 2004 | 05:06 PM
import_speedzz's Avatar
Well, i need to change my clutch real soon.. Its really badd already.. RPM doesnt even pull up 3500. RPM then goes up but doesnt want to go up 45mph... I got it checked and said its my clutch.. Whats the nice brand out for the Lancer besides RRM? Any Japanese brand out? OR does ACT have one for lancers?
Old Jan 30, 2004 | 05:28 PM
sjl6102's Avatar
i had 24,000 miles and my clutch chattered and slipped really bad. no grinding but when i replaced it, the pad wasn't worn out but the springs in the center of the disk were very loose. I replaced it with the road race kit and it was a lot better. the pedal is heavier but you'll get used to it and when it's broken i was able to chirp into 3rd gear.
Old Jan 30, 2004 | 08:26 PM
HobieKopek's Avatar
1.8l 4g93 Mirage/Lancer pressure plates and clutches fit, but you will need a 4g94 TO bearing.
Old Apr 30, 2005 | 08:47 AM
Pick_a_Fro's Avatar
so all pressure plates fit? I'm asking because on sites there are different types of pressure plates for ACT Clutches. There is stock plates, 4 puck, 6 puck, and street. Does it matter which pressure plate? I'm thinkin of street, but I just wanted to ask first before I buy.
Also heavy duty vs. Xtreme ACT clutch? I'm thinking of Heavy Duty, but i'm mostly N/A so Xtreme would be too extreme eh?
Old May 1, 2005 | 10:39 AM
Blacksheepdj's Avatar
Yes, it matters. I don't think they're universal. Get a pressure plate for a 1.8L Mirage.
Old Sep 24, 2005 | 09:40 AM
grubiaco's Avatar
Hobie do you have any sites that have the 1.8l 4g93 Mirage/Lancer pressure plates and clutches.
Old Sep 25, 2005 | 05:36 PM
chummer-x's Avatar
is the RELEASE BEARING AND THROW OUT BEARING the same thing???
Old Sep 25, 2005 | 07:13 PM
maxum17ft's Avatar
yup, mitsu likes to call it the release bearing, tob is the same thing.
a release fork however is different, but dont worry, our cars have that built in with the bearing.
Old Feb 13, 2010 | 09:36 AM
Twitch377's Avatar
Hello all, I need inputs on my issue, i have 119K miles on my stock Clutch assembly and it decided to go out on me last night, i am getting a horrible gear oil smell when i come to a stop! is this normal for a clutch when it goes out? or is my input shaft bearing going bad and allowing oil through the bearing and onto the clutch disk?
