Lancer ES transmission issues
A friend of mine is having some problems with her '08 ES A/T. She said she was in traffic and the car stopped accelerating. After that the car takes off very slow and will not go above 70. I looked at the car today and it feels like the car may be stuck in a limp home mode or locked into a single gear.
She doesn't have a owners manual as she bought the car used. The car was also in an accident prior to her buying it. The radiator is pretty beat up as is the condenser. My main questions are:
1) What does limp home mode feel like in the Lancer.
2) The LCD screen shows a small down arrow with a line under it in the upper-mid right corner. As I do not have the owners manual I don't know what this means.
3) What else can prevent the CVT from "changing" gears?
-Josh
-Josh
I would get any codes read out for the trans. It does sound like limp mode to me. I own a 5 speed, but the cvt is just limiting speed and acceleration to protect itself due to a fault in the system. Get the codes and go from there. Does she still have powertrain warranty?
Is it possible to read the codes with a standard scanner (available at autozone) or is the MUT required? I would also like to know if there are any dashboard indicators for limp mode.
The vehicle should still be within the 10yr/100000 mile warranty but I am 1) not sure it has been transferred to her, 2) will be honored due to the accident.
My theory is that the radiator damage has allowed air into the system and is at a reduced cooling performance. The air/reduced cooling is creating higher than normal trans fluid temps which is causing the vehicle to go into limp mode.
The owner has been able to go to one shop that scanned the transmission and they told her she needed a new one, but with no reason. As for the radiator it looks like the end tank has been epoxied back together, so I do not trust the cooling system at all.
-Josh
-Josh
If there is a transmission fault, a gear symbol will pop up in the drivers display with a service required or a temperature symbol also telling you to slow down.
The transmission cooler is a separate heat exchanger from the radiator, but if the radiator is damaged and you have lost coolant, you may have a heat issue. But doubtful, as the engine will be overheating as well.
With the damaged radiator, it will not suck air into the cooling system, it will leak coolant out. Simple test, open the radiator cap (cold), is the fluid at the neck?
I have not tried to read a cvt on a mitsubishi, but any decent scanner should read the codes.
Another question, is there an ABS light? The speed sensor for the transmission is read from the ABS tone rings on the wheels.
the warranty should be valid, they go by VIN usually, unless they want to be complete ****** and not honour it because it wasn't properly "transferred" over. I would just call the dealer and see, it doesn't hurt.
Thanks for the help.
-Josh
Also on the warranty if she is not the original owner the car only has a 5 yr / 60 k mile warranty http://www.mitsubishicars.com/MMNA/j...te/warranty.do
MadBoost23
Lancer Engine Management / Tuning Forums
Jun 10, 2015 11:57 PM
