Tempuature control knob.. Stuck on hot, wont turn
Old Oct 18, 2012 | 03:18 PM
Chris D.'s Avatar
I'm having issues with the temp control knob,
it's pretty much stuck on hot, I turn it to cold and it fights me and ends up poppin back over to hot..
I didn't want to force and break it.
Any solutions?
Thanks
Old Oct 18, 2012 | 03:25 PM
03lances's Avatar
Common issue with our cars. I would start by pulling out the Hvac and disconnecting the cable to see where the issue is. There is plenty of info on here about this problem I would search around too.
Old Oct 19, 2012 | 05:37 AM
Chris D.'s Avatar
I've done a few searches prior to starting this post and didn't find what I was looking for.
Do you know the title to the thread or can you point me in the right direction?
Thank you.
Old Nov 28, 2012 | 03:16 AM
MrBRoced's Avatar
Hey just to let you know I have had the same problem and you can go under the dash on the drivers side you will see a white plate with another plate on it with what looks like a bike brake cable something like that but yes you can manually flip it from hot to cold or vice versa.. I tried everything to fix it but you need a new cable I assume but this works for me it's a pain in the a$$ sometimes but it works! hope this helps!
larlo
Lancer Troubleshooting
14
Mar 4, 2025 02:41 PM
Chris D.
Jul 29, 2015 11:24 PM
Stosskraft
Jan 14, 2014 04:34 PM
d15b7
12
Jul 26, 2009 04:48 PM
OZR_Lancer
Nov 19, 2008 08:12 AM
