Help with HO alternator!
Old Dec 10, 2012 | 02:50 PM
MrBRoced's Avatar
Question Help with HO alternator!
Hey I just installed a high output alternator which people have gotten and I know they sell quality product but! Ever since I installed it when I idle it's at anywhere from 12.8-13.5 when I'm driving it's at 14-14.1 which is strange cause my stock would idle at 14.2-3 now I'm curious if it's the alternator or maybe cause the cpu reset? or the battery terminals need to be cleaned? I mean it's kinda strange that it goes from 14 driving to 13 idle and the alternator is supposed to be 140 amps and 75 amps idle which is almost a regular alternator at capacity what gives? Should I uninstall it and put the stock back in? PLEASE HELP!!!
Old Dec 10, 2012 | 04:17 PM
Steven's Avatar
I'd swap the stock one back in to test. It doesn't take that long. Then you'll know if it's a problem with the new alternator.
Old Dec 10, 2012 | 06:11 PM
eusgen's Avatar
Mine idles about 12.5 to 13 as well
Old Dec 10, 2012 | 07:03 PM
WikdEvo's Avatar
is this with a stock pulley or underdrive pulley?
Old Dec 10, 2012 | 09:38 PM
MrBRoced's Avatar
Stock I'd assume or so the lady from the company told me..
Old Dec 10, 2012 | 09:40 PM
MrBRoced's Avatar
Dude if yours is idling at 12.5 to 13 something is seriously wrong esp if you have a system in your car you'd be killing your battery weekly!
Old Dec 10, 2012 | 09:50 PM
WikdEvo's Avatar
From what I've read. H.O alternators require an underdriven pulley to make higher voltage at idle.
Old Dec 10, 2012 | 09:52 PM
WikdEvo's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=635231
Old Dec 10, 2012 | 11:05 PM
MrBRoced's Avatar
Even if it needed it which I'm not sure it's not the issue the issue is I'm getting like 12.8-13v idle and I don't know why when with my stock alt I was getting 14.2
Old Dec 10, 2012 | 11:16 PM
WikdEvo's Avatar
throw the stock one back on there and check the voltage. If it is at 14 then its the alternator.
Old Dec 11, 2012 | 03:58 AM
MrBRoced's Avatar
I know I didn't install the alternator though long story I was hurt in a motorcycle accident and can't use my right hand the best so I had my shop do it but that's what's gonna happen
Old Dec 11, 2012 | 07:09 AM
eusgen's Avatar
I can't recall if I installed my volt gauge before I installed my H/O alt so idk.
I have been running this alt setup for almost two years now and I have not killed any batteries or anything of the sort. I can tell you I noticed the difference when I put in the H/O alt compared to stock.
Old Dec 11, 2012 | 09:31 AM
MrBRoced's Avatar
I just realized what one of the main problems are.. The fan control module is shot it has a recall for this year and when the fan is running which is most all the time the voltage is hammered! BUT when it's not running it's 14.2 also being I reset the cpu it gets kinda iffy for a while or at least that's what I've noticed till it gets the data etc I started my car up today and had a voltage of 14.7 true voltage but that fan kicks in and slowly knocks it down.. At least I know it's not the alternator now!
Old Dec 11, 2012 | 02:33 PM
MrBRoced's Avatar
I take back my previous comment I went to the store a few minutes ago tuned the lights on and bang 12.8v.. I will be putting in the stock alternator tomorrow and live with it that's all
R/TErnie
190
May 22, 2026 07:59 AM
lil' jeff
Nov 17, 2022 03:25 PM
kaj
Jan 27, 2017 03:45 PM
sti killr
Jan 1, 2011 12:46 PM
jwick76
Lancer Troubleshooting
Apr 3, 2009 03:03 PM
