Help Pleeease!
Old Apr 29, 2013 | 06:03 PM
gyalflexfameh's Avatar
Question Help Pleeease!
What I have Noticed :
- Engine cranks fine but doesnt turn over
- Dome light doesn't work / come on
- Power lock doesn't work when I press the lock/unlock button, works when i put the key in the on position and then press the lock/unlock button.
- What would cause no power to Fuses # 20, #21, #22 and #23?
- Original Keys factory alarm buttons no longer work
- Aftermarket alarm is arming and disarming but not actually shutting the locks
Thoughts:
- I have Checked the battery, and to be sure i bought a new battery to check it out
- If there is no power to some fuses, could this be a relay issue? and also if there is no power to certain parts of the car, then the alarm wouldn't work properly causing the engine to shut off.
Pictures attached are the fuse boxes. One in the engine compartment and the other under the drivers side.
I cannot find diagrams of anything to describe the relays and what they are used for. Owners manual only gives the diagram for fuses.
I am not a mechanic, and also the dealership where i live are very expensive and are not helping at all.
Old Apr 30, 2013 | 07:53 AM
Veronica's Avatar
wow. Who installed the aftermarket alarm? I would go to them. Mitsu will say the same.
If the FAST system is no longer 'seeing' the chip it will not let the engine start. Are you seeing the key logo on your attempts to start it?
Old May 1, 2013 | 05:06 PM
I found out what the problem was after taking it to the mitsubishi dealership. It was a blown relay and and 2 blown fuses. It wasn't sending signal to the fuel pump and it also cut off power to the alarm so that shut down because of the anti theft system. It didn't cost me anything luckily.
Old May 10, 2013 | 06:29 AM
HatrixMouse's Avatar
Yeah, I was about to ask if you were still under warranty, for having a car that's only 3 years old. But fortunately they were able to fix the problem!
.. holy crap, that may be a +1 for the stealerships.
Ancyker
22
Apr 4, 2016 04:58 PM
NewfieG
Feb 15, 2016 07:50 AM
19.5PSI
Feb 18, 2014 05:29 PM
Qwest905
Lancer Troubleshooting
Dec 4, 2010 02:25 PM
WRC4ever
Jan 29, 2004 08:31 PM
