Intake into AIRFLOW SENSOR?
Old Jul 29, 2002 | 06:58 AM
nonforu's Avatar
Question Intake into AIRFLOW SENSOR?
How can i connect my new short ram Intake to the stock Airflow sensor? The Sensor connector is SQUARE... the pipe off my filter is ROUND.. the two dont mix but somehow RoadRace did it and coverd the connection in their picture...???! I dont wanna run without the sensor cuz the Service Engine light will always be on... what do i do? Someone help me PLEAZE
Old Jul 29, 2002 | 07:00 AM
cleofis's Avatar
uhh..i think you connect it to that..just take off the stock air box..and after that grueling stage with the 4 screws that are so friggin hard to take off from the plastic air box back part..you should attach the new air intake directly to there. i hope this helps! goodluck
Old Jul 29, 2002 | 07:04 AM
pjal84's Avatar
Not quite cleofis...he's already taken off the air box.
Notice how in this picture the heatshield is a combined shield and bracket? The cone will secure itself to that round flange on the side facing us, from there, you see the rectangular whole which leads to the MAS and the honeycomb mesh. On the other side which we can't see is a bracket which will secure the shield to the MAS assembly. You need something similar.
Old Jul 29, 2002 | 07:07 AM
nonforu's Avatar
Question INTAKE QUESTION ONCE AGAIN
OK.. I dont think i made my message clear before... i bought another intake... NOT FROM RMR.... and i wanna be able to put it onto the air sensor... but i think i need some kind of MAS adapter or smthn
BYE THE WAY.. what happens if i just leave the service engine light ON?
BY THE WAY #2... i get a funny smell from my car after i turn it off.. kinda smokey burny smell but not so strong.. and ONLY FOR A few seconds.. waht could it be?
Old Jul 29, 2002 | 07:09 AM
nonforu's Avatar
I SEE THE LIGHT
REEEHEEEEEHEEEE HEEEEEEEEEEEEEEEEELY..... ide never seen that before... i STRONGLY Doubt theres any way i can get that sheild..
Old Jul 29, 2002 | 07:11 AM
pjal84's Avatar
I know you don't have the RMR one otherwise you wouldn't be having this problem. I was telling you that you need an adaptor. Round hole to a square hole in essence. Look here at this other custom intake. Notice the silver bracket highlighted in the oval. You need to acquire something similar. Ask member loneeemeeee for assistance if necessary.
Old Jul 29, 2002 | 07:14 AM
Lancer03's Avatar
Thats a pretty cool intake, did you make it for your Lancer?
Old Jul 29, 2002 | 07:20 AM
2wdSQL's Avatar
I made that with parts from home depot and RRM.
Old Jul 29, 2002 | 07:26 AM
nonforu's Avatar
hmmmm intakes at home depot?
wat could u find at home depot?
Old Jul 29, 2002 | 07:28 AM
cleofis's Avatar
that burny smell might be your tires. drive fast? burning rubber!!
that my best guess..cause i usually get that a lot too
Old Jul 29, 2002 | 08:25 AM
2wdSQL's Avatar
If you drive a manual that smell is probably your clutch either that or you are burning up catalyst. The part I got from home depot was the 2 1/2" to 3" connector($6) I got the MAS adapter plate from Road Race Motorsports with my original short ram intake. I'm sure Rob would be more than willing to sell you just the plate.
Old Jul 29, 2002 | 08:27 AM
liquidlancer's Avatar
if you leave your o2 sensor off and your check engine light is on it is bad
do not run the car without an o2 sensor
if you run the car witch out the o2 your computer doese not add as tot he air fuel mixture therefor making the car run on air basicly witch make increadible amounts of heat making parts start to melt
buy a ROAD RACE
ROADRACE KICKS
Old Jul 29, 2002 | 10:55 PM
NoPstns's Avatar
buy a ROAD RACE
ROADRACE KICKS
You can't be serious.... doesn't add the air/fuel mix? Find whoever told you this and beat their ***. If for some strange reason, the lancer actually does that, find the engineer at Mitsu and beat their *** instead
Old Jul 29, 2002 | 11:05 PM
Autobot's Avatar
I just wanted to stress some key points that might have been missed:
-Make sure the filter that you have has a 4.5" inlet opening. Most filters are 3"
-Make sure the MAS adapter that you get is 4.5" and not 3" (this will be a given if you order it from Road Race)
-If the filter that you do have is 3", you still need to get a 4.5" MAS adapter, and a 3" to 4.5" reducer sleeve as well to connect the two (an adapter for your adapter essentially)
Old Jul 29, 2002 | 11:14 PM
dude do you even knwo what a MAS doese?
it measures how much air is going into the engine and ajust the fuel injectors acordingly without the MAS the ecu would not know how much fuel to add. . . how is that not right and how is mitsu responsible for that all cars are liek that that have MAS
