Engine ? Computer System ? i dont know
Old Feb 20, 2004 | 06:00 PM
lancer-0Z's Avatar
Unhappy Engine ? Computer System ? i dont know
something is wrong with my A/T OZ
the problem happened after i changed my tail lights, everything works fine when the headlights and parking lights are off.
what's weird about it, is that when i turn either or both of parking lights and headlights on, and if i put it in the R position, the engine jumps so hard instead of quiet and smooth. while the headlights or/and parking lights are on, position D, 3, 2, and L are not working....
im wondering if any of u guys ever had such a problem?
by the way, im calling the roadside assistance to get my car towed to the dearler tomorrow
much appreciated
Old Feb 20, 2004 | 06:21 PM
rhitme03's Avatar
Sounds like you might have a ground off - that would be a good place to start... Funny things happen when you don't have good ground.
Old Feb 20, 2004 | 06:25 PM
lancer-0Z's Avatar
ground off ? what do u mean by that ?
Old Feb 20, 2004 | 06:32 PM
rhitme03's Avatar
I mean when you changed something you may have a ground wire that is loose or no longer grounded to the body. If that's the case, you end up with an open circuit which can do some really goofy things to electrical systems... I'd take a look at the wires to make sure they're all connected properly.
Old Feb 20, 2004 | 06:44 PM
lancer-0Z's Avatar
sounds reasonable but why does it have to be only when i turn the headlights on ?
Old Feb 21, 2004 | 06:35 AM
Blacksheepdj's Avatar
Granted, I know very little about electrical systems, but maybe when you turn on the headlights, it sends electrical current to the taillights. If you have a lose ground wire, then this electrical current could be causing the problem. Hence, if the lights are off, then no problems.
Old Feb 21, 2004 | 07:24 PM
lancer-0Z's Avatar
which ground wire tho ? i could only think that it might be my deck wire
Old Feb 22, 2004 | 08:45 PM
HobieKopek's Avatar
Gonna move this to troubleshooting since you're pretty much asking for people to...well...troubleshoot.
Old Feb 25, 2004 | 10:10 PM
twinlancers2's Avatar
with your light's off your not using as much power as when you have them on, now what could be happening is that with them on and not having the ground your surging the electrical system, and like blacksheep said weard **** happens with a slightly open circiut, also you could have a small short as well
EvoLLBlue8
Jun 23, 2017 09:39 AM
evox_4x4
Dec 20, 2015 09:42 AM
erald01
Jul 22, 2011 10:03 AM
warr40
Lancer Troubleshooting
Oct 7, 2009 08:39 PM
MIevo8MR
Jun 7, 2005 09:42 AM
