Need help with programming new remote
Old Aug 6, 2013 | 10:24 AM
cvoeb's Avatar
I followed the steps and nothing happens. in step 2 it says leave keys in the off position. Can someone clarify the "off" position, I've tried it a couple ways.
1. Locate the Data Port under drivers side dashboard usually located to the right of steering column.
2. Insert keys in ignition and leave in the OFF position.
3. Make sure there are metal contact pins in terminals 1 and 4 and connect the Data Port terminals 1 and 4 with a
suitable jumper wire, leave the jumper wire connected throughout the programming procedure. Make sure you
know which terminals are 1 and 4.
4. Within 10 seconds after connecting the jumper wire, press the Hazard Switch 6 times. Note: The doors will
automatically lock and unlock once at this time indicating that the system is in the programming mode.
5. Press the LOCK button on the remote to be registered three times within 10 seconds. Upon successful
programming, the door will lock and unlock once.
6. Repeat step 5 with up to 4 remotes (including any existing remotes) within one minute. After completing each
programming, the doors will lock and unlock once.
7. Disconnect the programming wire and remove the keys from the ignition.
Old Aug 6, 2013 | 08:06 PM
Automatic 51's Avatar
I want to say I read somewhere the door had to be closed but that could be just me mixing something up. Aside from that those are the steps I've seen on here before but I have never done this before.
Old Aug 7, 2013 | 01:17 AM
cvoeb's Avatar
ok let me give that a try, pretty tight squeeze with the doors closed though.
Old Aug 7, 2013 | 05:55 AM
eusgen's Avatar
If you purchased a remote that has the "trunk" button it might not work if your car doesn't have that option, or maybe if it doesn't have the "trunk" button you need the one that does? Just a thought cause I bought one a while back with a trunk button hoping it would work but it didn't do anything I have a 2002 OZ rally tho.
Old Jan 22, 2015 | 12:13 PM
koketo72's Avatar
only for 2002-2007? i have 2009, where is the hazzard button
IDRINKV8
Nov 18, 2015 08:01 PM
Psybin
Evo X How Tos / Installations
Aug 29, 2014 12:41 PM
motion3131
For Sale - Cars For Sale
32
Jul 18, 2014 01:26 AM
r34p3rex
10
Mar 20, 2014 10:24 AM
lancerguy0208
May 4, 2010 02:55 PM
