2009 mitusbishi lancer A/C unit - help ???
Old Mar 16, 2014 | 01:24 PM
3d1l's Avatar
Hi first post in the forums
I've been lurking the forums for some time but cannot find a specific answer to my question. Please let me know if this is not the correct sub-forum.
I bought an used 2009 Mitsubishi Lancer. When I turn on the A/C unit it emits a loud "clack" or "click" noise that can be heard inside the cabin even with windows closed. That could be probably normal when the A/C is activated for the first time, but the thing is that each time the A/C activates to keep the temperature inside the cabin, the noise can be heard and it do it a lot of times. The sound is so loud that I can be driving with windows closed and still can hear it. There is no sound if I only left the fan working. I constantly have to use the A/C because I live in Puerto Rico and it is constantly hot and humid here (typical tropical weather). With the A/C active the air flow is constantly cold and never fades out, like blowing warm or hot air unless I change the thermostat.
Is the constant "claking" sound normal? because it is very annoying
Old Mar 19, 2014 | 10:56 AM
Veronica's Avatar
You have a relay that switches on the compressor and could be the culprit. Swap it with a similar (same p/n) relay (like the horn relay if the same) and then listen to determine if that fixed it.
Old Mar 21, 2014 | 06:04 AM
3d1l's Avatar
Thanks Veronica,
I finally went to a mitsu dealer and they told me that there is nothing wrong with the A/C the clacking noise comes from the compressor's clutch. I'm gonna have to get use to the annoying sound.
Old Aug 7, 2014 | 06:22 PM
hutch959's Avatar
mine does the same thing... btw
rayman0690
Jan 4, 2026 07:20 PM
usnevo8
Aug 24, 2019 03:05 PM
Lancerzz
Sep 23, 2014 06:02 PM
jrsimon27
Feb 19, 2010 03:33 PM
ultraflip
41
Jul 22, 2008 06:50 AM
