08 DE misfiring with no code
Old Jul 1, 2014 | 10:14 AM
verticalspark's Avatar
I have a 2008 Lancer DE that is misfiring, 65,000 miles, oil changed 2 weeks ago but not throwing an engine code. Misfire when idling and low rpm. I havent swapped spark plugs as I changed them out last month. I checked all the local parts stores for coil pack but nobody has them in stock and it will be 7+ days for those that can order them.
Has anybody else had problems like this or have any ideas?
Adam
Old Jul 2, 2014 | 05:45 AM
Veronica's Avatar
Did it start misfiring soon after you changed the plugs?
-check gap
-check spark plug torque
-replace the plugs again (not impossible to get a bad plug from the factory). You could buy just one spark plug and keep swapping until the problem suddenly goes away - indicating which spark plug was bad...
If not:
-I would run seafoam[tm] through the gas tank (for a partially clogged injector (and then seafoam
the intake through the brake booster vacuum line since you are at it).
-Lastly, check compression.
I doubt it is a coil.
Old Jul 3, 2014 | 03:33 PM
Thanks Veronica, looks like one of those tricks worked. I replaced all the plugs and used the seafoam. Im not going to guess which one it was but the car runs.
Thanks again
Adam
Ztevo93
Lancer Troubleshooting
Jan 12, 2015 11:34 PM
bjstrick
13
Jul 11, 2012 05:14 AM
DsmSpeed
12
Sep 4, 2010 01:19 PM
bboy_RES
Jun 7, 2008 02:21 AM
PurEvo
23
Mar 6, 2007 07:58 PM
