problem with a EVAP HOSE, dont know where to plug
Old Oct 27, 2014 | 11:26 PM
danieluc1's Avatar
Hello, im new on this forums and i hope this thread can help me to solve this issue,
look, im a proud owner of a Good Lancer 2003 ES, it was in a yunk yard and i decided to repair it up, had to pull the engine out to rebuild it with a new crankshaft and some connecting rods, everything gone OK except of that there are 3 Lines that comes from the under neath of the car and 2 of them plugs to the Injectors rail, so that means they are the Fuel in line and the Return line, they are ok but the third line turns in to a Hose that i dont know where to put it on, i have looked everywhere and nothing, i have no clue on where to put it on, im pretty sure that it must go on a part of the EVAP system because when im runing the car, there is a GAS smell that goes inside the car, and when its off, you can approach that hose to your nose and it smells as gas, so there is some one with a ES that can tell me where i have to plug it on?.
also i have several codes that i will be reosiving step by step, the relevant code on this thread is the P0455 which is EVAP emissions control system leak detected.
hope you can help me, thanks in advance
Old Oct 28, 2014 | 12:17 AM
i8acobra's Avatar
Not sure about your Lancer, but most cars have a purge control valve under the hood. That hose goes to the purge control valve which then goes to the intake manifold.
Old Oct 28, 2014 | 07:23 AM
danieluc1's Avatar
Thanks for your reply, i have checked that already, and i wasnt able to find that Purge Valve, also i checked on Alldata, and cant find the part number to see how that Purge valve looks like, some one can help me out to find where that valve should be?,
im pretty sure that my lancer dont have it.
thanks.
Old Oct 28, 2014 | 08:29 AM
Ev0ikon's Avatar
If you rebuild a junk car it's a good time to delete emission stuff too :}
Old Oct 28, 2014 | 08:34 AM
danieluc1's Avatar
Delete Emission suff?. that sounds NICE, can you tell me more about it, or where can i find information of that?
Old Oct 28, 2014 | 09:14 AM
Ev0ikon's Avatar
Good news for you this forum is full of that info. Start reading my friend!
Old Oct 28, 2014 | 12:20 PM
danieluc1's Avatar
have searched on the forum for the information and there was just Information for EVOs, cant find for Normal ES lancer, no matter if there is a guide for my car, i dont think i need to do that stuff, but still have my problem with that HOSE, please some one tell me how to find what is laking on the car, just cant find where to plug it.
Old Nov 2, 2014 | 07:53 PM
i8acobra's Avatar
This is what it looks like:
This is where it is (location C):
Old Nov 4, 2014 | 08:01 PM
danieluc1's Avatar
Thanks for your reply, i have checked that information on alldata already and have checked on the car aswell, and everything on that Area looks pretty Good, so i dont think there is the problem, will take some pictures tomorrow so you can se wich hose i mean.
Jaspreetsingh93
Oct 9, 2013 02:27 PM
apiazza2010
Aug 2, 2013 01:05 PM
NewEvolutionIX
24
Sep 23, 2010 06:18 PM
Johnboy1065
11
Jan 14, 2008 05:37 PM
lemacfar
Jun 20, 2004 09:27 AM
