09 lancer gts dies and I need help!
Old Jan 30, 2015 | 09:05 AM
Missa25o's Avatar
Unhappy 09 lancer gts dies and I need help!
I have a 2009 lancer gts. Car runs fine until it warms up then while I'm driving all my hazard lights will come on and I'll loose my speedometer and rpms then it'll just die. If I turn it off and try and restart it won't start until it's cooled off again. Mitsubishi dealer ran a diagnostic and fixed any sensor recalls and it didn't fix the problem. The closest dealer is over 2 hours away so I want to fix myself but I don't know what the problem is. Anyone had this problem before
Old Jan 30, 2015 | 11:14 AM
Wicked Doc's Avatar
Sounds like ignition problem. Coils, distributor? Something's overheating there, causing the shutdown. It also could be ECU overheating... I believe Autozone does distributor tests
Old Feb 1, 2015 | 11:40 AM
CamShaft's Avatar
sounds like a power or ground issue to one of the ECU's. Check your battery and connections. Could also be a data link issue. Check for any codes.
StormGTS
Lancer Engine Tech
May 10, 2018 12:25 PM
WeGotTheSTEEZE
Lancer Troubleshooting
Feb 26, 2015 08:25 AM
LancerGtsKid
Lancer Engine Tech
Jul 18, 2010 05:22 AM
w.c.z
15
Jun 7, 2009 06:12 PM
