2008 Lancer GTS no start please help
Old Jun 22, 2015 | 06:21 PM
Bgrimm1's Avatar
I have read many threads and there are alot of possibilities. New to Lancer its actually my girlfriends car. She left her sunroof open one night and we got alot of rain. Next day car wont start appears to have no spark. Car ran fine when she parked it. Now is also throwing a code p0340. Not sure how to get to the camshaft sensor or if i should start somewhere else. Thought it might be the timing chain it appears to be loose but not sure exactly what is okay and how to check timing. any help would be greatly appreciated
Old Jun 22, 2015 | 06:24 PM
Bgrimm1's Avatar
pics wont post
Old Jun 23, 2015 | 09:18 AM
Veronica's Avatar
The two events may be unrelated. Change the cam sensor first.
Old Jun 23, 2015 | 09:37 AM
Bgrimm1's Avatar
Happen to have a diagram that shows where the sensor itself is? Having trouble finding one on Google.
Old Jun 23, 2015 | 08:06 PM
CamShaft's Avatar
Hopefully this diagram helps.
File Type: pdf
Old Jun 24, 2015 | 06:48 PM
Bgrimm1's Avatar
Thank you that did help. I believe my sensors are good and after looking closer I believe it has jumped timing. The timing chain is pretty loose as well. When replacing the timing chain do you suggest replacing the other chain at the bottom as well?
Old Jun 25, 2015 | 09:22 AM
CamShaft's Avatar
I doubt it has jumped a tooth. The timing chain is supposed to last a very long time. the code you are getting is not generally a mechanical related fault. Most likely a sensor or circuit fault. Try swapping sensors and see if the code changes.
TROUBLESHOOTING HINTS (The most likely causes for this code to be set are: )
•Intake camshaft position sensor failed.
•Open or shorted intake camshaft position sensor circuit, or harness damage, or connector damage.
•Intake camshaft failed.
•ECM failed.
If you really believe the timing chain has jumped a tooth. Pull #1 spark plug set to #1 TDC firing and the timing marks on the camshafts should line up with the cylinder head facing inwards to each other.
Old Jun 25, 2015 | 09:33 AM
Bgrimm1's Avatar
•ECM failed.
Yeah I checked that and the camshaft closest to the front is lined up but the camshaft in the rear is at about 5 o'clock instead of 3 and the chain is very loose
Old Jun 28, 2015 | 08:15 PM
CamShaft's Avatar
The camshaft closest to the front (intake) should be at 9 o'clock and the exhaust (rear one) should be at 3 o'clock when at TDC 1. Swap the sensors. See if the code changes. Test the sensor circuit to the ECU.
Old Jun 28, 2015 | 08:18 PM
CamShaft's Avatar
Here's a schematic to test the wiring.
File Type: pdf
Glindsey285
Jul 19, 2018 03:03 PM
nlp187
Jul 8, 2012 10:32 PM
geevolution
Dec 31, 2009 05:31 PM
MujahidMD
Apr 6, 2009 11:34 PM
