No heat from blower motor
Old Nov 27, 2015 | 04:35 PM
apitman1's Avatar
For the last 2 weeks I was unable to get heat from my blower, I found the fan wasn't working in slow speed so I checked the resistor and later replaced it, the fan is now full working but I cant get any heat from it?? when I was driving to the garage to get my new resistor I encountered another problem with my car, I was on a gradual slope and as I tried to accelerate my car wouldn't go above 2000rpm and when I looked at my temperature gauge it was reading very high. As I got to the garage the temperature gauge had dropped away again to normal and I noticed it was fluctuating quite drastically. The guy at the garage says it is not linked to the blower not giving out heat and suggested it may have something to do with EGR valve sticking?? or fuel injectors being dirty?? Any help on either of these issues would be much appreciated.
Thanks
Its a Mitsubishi Lancer GS4 2.0l DiD
Old Nov 27, 2015 | 05:45 PM
detroit pistins's Avatar
Possible air pocket in the system....
Ask your mechanic to bleed the radiator/coolant system. He should know what to do from there. Make sure your blower/heater is turned on on full hot while the test is conducted.
GL!
Old Dec 1, 2015 | 07:18 AM
Veronica's Avatar
Make sure you have coolant in the radiator (a very low level would do this).
Old Dec 2, 2015 | 01:08 PM
apitman1's Avatar
Thanks for the help, turns out my radiator had a bad leak and was causing these issues. New radiator fitted and running well again.
Old Dec 3, 2015 | 08:10 AM
Veronica's Avatar
GetFoxed
Jun 12, 2019 04:56 PM
stealthlancerOZ
Lancer Troubleshooting
52
Sep 19, 2014 10:17 AM
19DB794
Jan 2, 2014 05:21 AM
peeps
Jul 25, 2011 02:28 PM
BigP436
Jun 12, 2005 08:18 PM
