2008 Lancer es AC not cold
Old May 31, 2016 | 11:37 AM
CMcraz23's Avatar
Hello,
Never had a issue with my AC until today. It has been consistently high 85 and up here in central PA and today was no different. The AC will work, but it isn't freezing cold as usual. I have it on max AC with blower speed a little less than half way on.
Any ideas why it all of a sudden doesn't want to work?
105k miles
Never had any work on ac unit, no issues.
Thanks
Old May 31, 2016 | 12:19 PM
Veronica's Avatar
Try a can of refill (at parts store). Follow the directions and precautions. Best can has a beefy black plastic gauge on it.
If it only works for a little while (days or even only a month) - you have leak. Go to a a/c specialist.
Old May 31, 2016 | 03:57 PM
CMcraz23's Avatar
Thank you for the response! What brand would it be, sorry a noob question.
Old Jul 12, 2016 | 01:08 PM
CamShaft's Avatar
Putting a can of refrigerant is a short term solution.
You either have a leak, a sensor, fan, or compressor problem. Since you haven't complained about overheating, I would rule out the fan.
Unless you have the pressure gauges, you will need an a/c professional.
Old Jul 14, 2016 | 05:44 PM
Newuser213's Avatar
I have a 2012 ES and i'm also at 100K. I recently noticed that the AC
vents on the passenger side are blowing out warm/normal air while my 2 vents
are blowing out cool air(weak cool air even at MAX). Any idea guys?
Also is my Lancer dual zone control? I'm thinking about doing a recharge and hope
it fixes the problem.
Old Jul 19, 2016 | 10:19 AM
Veronica's Avatar
Nope, not dual zone...
Like stated above, the recharge is a short term fix -but helps troubleshoot the issue.
The can has a gauge and directions - it will tell you if the system is charged (stop. It is something else) and how much to fill (do not over-fill. Just follow the directions).
If the recharge fixes it - let us know how long until it stops working again. Also, look for oily/dirty spots around each hose connection.
MitsuNewbie
Lancer Engine Tech
13
May 5, 2008 06:52 AM
Roctght
Lancer Engine Tech
37
Jul 20, 2007 06:17 PM
acidandroid
May 6, 2005 11:15 PM
initialD
Lancer Engine Tech
24
Mar 20, 2004 11:37 PM
cacrawfo
AEM EMS
Feb 8, 2004 08:13 PM
