Weird cooling issue
Old Sep 23, 2016 | 07:39 AM
Animefreak1983's Avatar
Weird cooling issue
So I have a cooling issue like I've never seen before . On my lancer es as long as it's moving it stays at ideal temptations and no issues. But if sitting still for a little while it starts heating up to point it warns me it's rough hot , but once moving it goes right back down to normal .
Any cooling issues I've seen on a car previously they do it at all times . So this one's confusing to me .
Oh and my car is a 2013 lancer es
Old Sep 27, 2016 | 12:09 PM
Veronica's Avatar
Sounds like your fan(s) are not coming on.
If you turn on a/c do you hear the fan turn on?
Do you hear the fan when it is running hot?
Have you checked your coolant level (when cold - take the radiator cap off). Let us know how much 50/50 coolant/water it took to fill it (if low).
Old Sep 27, 2016 | 02:13 PM
kaj's Avatar
kaj
Make sure fans are working.
Make sure they are spinning the right way.
Old Oct 15, 2017 | 05:46 PM
jmh8723's Avatar
I had the same issue 09 lancer ES, then my compressor went out. Changed the compressor and the fan (vacuum+recharged the a/c after that) it fixed that problem but now my compressor blow off valve keeps going off when I drive for a while. Both fans turn on and so does the compressor. Trying to look for help. I live in Florida a/c is a most.
Old Oct 15, 2017 | 09:59 PM
4b11slayer's Avatar
Check basics
Fans
Coolant level
Any leaks?
Sounds like a radiator issue to me.
Old Oct 16, 2017 | 04:05 AM
jmh8723's Avatar
My radiator doesn't seem to be acting up. There is no spill any where and the coolent level doesn't go down. My compressor seems to building to much pressure, don't know why
Old Oct 16, 2017 | 08:49 AM
Veronica's Avatar
Pressure line kinked? Blocked? Condenser blocked internally?
Old Oct 16, 2017 | 11:55 AM
4b11slayer's Avatar
Too high of ac pressure is caused by a fan that isnt turning on to cool the ac gases. But shouldnt over heat the engine since there is something called a ac triple switch that will kill compressor to drop pressures.
alex the great
Jun 16, 2012 02:50 PM
Gruppe-S
51
Oct 15, 2009 12:36 PM
JKD
Aug 29, 2009 05:20 PM
eling99
Jun 15, 2005 07:23 AM
