Will dead transmission solenoid set off CEL?
Old Mar 6, 2017 | 01:19 PM
Chrushev's Avatar
I have a weird sound coming from the solenoid in the transmission when shifting from P to R or N to R or D. So basically shifting into 1st gear. Its a buzzing sound that lasts about 3 seconds then goes away.
My research points it to a solenoid in the transmission. Which I was quoted $360 for labor + parts for replacing.
I am curious if the CEL will go off once the solenoid dies? Or is there a chance it wont?
Also if the sounds happens when shifting to R or D from stop, its in 1st gear, is that indicative that the problem is with 1st gear solenoid? If that goes out, then would I be able to limp my car to a shop in 2nd or 3rd etc gears? Can/will this cause more damage?
Old Mar 6, 2017 | 02:17 PM
4b11slayer's Avatar
might be normal.
check fluid level.
Yes a bad shift solenoid should set a code eventually. Also might force transmission into limp home mode and lock it in 3rd gear failsafe.
Old Mar 6, 2017 | 02:45 PM
Chrushev's Avatar
Originally Posted by 4b11slayer
might be normal.
check fluid level.
Well the car has 86k miles on it (all driven by me) the sound just started a week ago so I dont think its normal. here is recording of the sounds:
So limp mode locks it in 3rd? What is 3rd gear is the bad solenoid?
Old Mar 6, 2017 | 03:11 PM
4b11slayer's Avatar
Originally Posted by Chrushev
Well the car has 86k miles on it (all driven by me) the sound just started a week ago so I dont think its normal. here is recording of the sounds: https://www.youtube.com/watch?v=ngE7yY4XSbk
Im not positive its 3rd gear on your car, but usually auto trans have a failsafe gear.
Old Mar 30, 2017 | 08:13 PM
Crazehen's Avatar
The trans will stick itself into the 3rd gear if you end up in limp mode. And to answer your question, yes a bad shift solenoid can cause a CEL, amongst many other drivability annoyances.
ChrisR
Sep 24, 2010 12:57 PM
turizmo01
Sep 12, 2010 10:47 AM
Evol X
Jun 12, 2010 11:02 PM
kalpakiotis
Lancer Troubleshooting
May 11, 2010 02:50 PM
razorlab
Mar 30, 2009 07:02 AM
