need help or service manual
Old Apr 20, 2004 | 10:43 AM
lancer02Josh's Avatar
hi i need to get a service manual or some help with my steering prob. The problem is that i can move my steering wheel left and right. and no i dont mean turning it. kinda like tilt but horizontal.. i took it apart and found these two little peices that seem to hold i there. i tightened them and it was fixed but as soon as i moved the tilt steering it got loose again. any help?
Old Apr 21, 2004 | 12:52 AM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
I has the exact same problem last year. I even crawled under the dash to try and tighten it up, then took it to the dealership. They tried to tighten it up too, then decided that the steering column was bad. They ordered the parts and replaced the entire steering column under warranty. It's a safety issue, so your local dealer should give no fuss about fixing it under warranty. And I know there's at least one documented case of such a defect (mine)
Old Apr 21, 2004 | 07:06 AM
40000 miles no more warranty..God that car is a peice of ****. So i have a messed up steering column and need a new one?
Old Apr 22, 2004 | 10:59 AM
Moderator
Bomb Squad Unit #02
I'd still see if I can get that fixed. Isn't there a law somewhere about safety issues and cars? I know my Trans Am had the seatbelts replaced under recall when the car was 12 years old with 100,000 miles. It's at least worth a shot, because this isn't any easy job.
Old Apr 23, 2004 | 10:25 AM
well its not a recall actually. I called them and asked them about it. It would cost about $400 for everything. Im not sure about any laws ill check up on that. Thanks alot.
n52b30
May 15, 2013 12:58 PM
Pimp Excape
Sep 18, 2010 08:33 AM
evilbada
Apr 19, 2008 04:27 PM
gvr4wd
May 26, 2006 07:35 AM
lancer02Josh
Lancer Troubleshooting
17
May 13, 2004 10:29 PM
