Mas Sensor
Old Oct 20, 2002 | 11:12 PM
ROB281's Avatar
Mas Sensor
I was changing out the intake on my car yesterday gpt everything switched out then I reset the battery on my car everything went fine the cel stayed off then I drove around the town for a while went home and shut it down then about an hour later I started it up again and the service engine light came I took the new intake off put all stock back on and reset the computer again now the light goes off but it runs like crap is it my sensor or did I not leave the battery disconected long enough?
Old Oct 20, 2002 | 11:20 PM
cleofis's Avatar
did you let your car idle after you installed? thats the only thing i can think of..let your car idle for 10-15 minutes after you turn it on with the aftermarket intake
Old Oct 20, 2002 | 11:24 PM
HobieKopek's Avatar
Did you reconnect the vaccuum hose that's supposed to go on there?
Old Oct 20, 2002 | 11:44 PM
ROB281's Avatar
Your talking about the hose on the back of the sensor right?
Old Oct 21, 2002 | 06:26 AM
pinoyesv6's Avatar
i'd make sure that everything is plugged in good and that the MAS is facing the right direction
Old Oct 21, 2002 | 11:18 PM
zilfrith's Avatar
In my case I have this same problem but I think you have to run with your car for about 4 days than after that it will go back in normal position or your sensor is gon it work for me
Zilfrith
awdordie
17
Feb 26, 2017 09:16 PM
TreatsIX
Jan 31, 2017 05:30 PM
mitsuclipsegsx
May 13, 2012 07:28 AM
merlin00069
Apr 27, 2009 08:56 AM
crow
Jun 26, 2005 11:56 AM
