eninge bogs when i give full throttle
Old Oct 25, 2002 | 08:54 PM
jab969's Avatar
Question eninge bogs when i give full throttle
i put a exausht on my lancer and cut out the resonater when i try to punch it the engine bogs when i get it going it dose not wanna shift what could it be??
Old Oct 25, 2002 | 08:58 PM
bahamut's Avatar
For someodd reason, your car is extremely rich, or your exhaust is too big.
What brand and size? Just exhaust work?
Old Oct 25, 2002 | 09:00 PM
jab969's Avatar
it dc motor sports
Old Oct 25, 2002 | 09:03 PM
bahamut's Avatar
what size? did the 2nd O2 sensor get messed up?
Old Oct 25, 2002 | 09:04 PM
jab969's Avatar
i could not tell u but i took it of a civic i think
Old Oct 25, 2002 | 09:06 PM
jab969's Avatar
so i should change exhaust u think?
Old Oct 25, 2002 | 09:14 PM
bahamut's Avatar
Your answers are preety vague. It's awfully hard to tell.
get me a link of the exhaust.
It's more likely the 2nd O2 sensor was damaged. The CE light is on or not yet.
Old Oct 25, 2002 | 09:18 PM
jab969's Avatar
no the ce light it not on i got the exausth from a friend it was running fine when i left the mufler shop then i drove home then left got on us-1 then when i got of it was not shifting nor going fast at all it has no pick up what so ever
Old Oct 25, 2002 | 09:22 PM
bahamut's Avatar
hmmm . . . no CE light does not indicate sensor failure.
I don't know if you have an exhaust leak. If so, I don't think it should affect performance in bogging down.
A cheap way . . . disconnect your battery for 3-5 mins and plug it back. Drive about 40 miles or so, your ecu should compensate.
Old Oct 25, 2002 | 09:24 PM
jab969's Avatar
so try to take it on the high way and seee if it fixes it
Old Oct 25, 2002 | 09:26 PM
jab969's Avatar
i am gonna check to see if there a exhaust leak
Old Oct 25, 2002 | 09:33 PM
bahamut's Avatar
If you just replaced your muffler, it shouldn't make your car bog down like that, unless it's too big. Again, you did say it was off a civic, and they are really known to use too big of an exhaust.
Do this if the problem is an unknown factor? If this doesn't solve it, something must have happened in the muffler shop.
"A cheap way . . . disconnect your battery for 3-5 mins and plug it back. Drive about 40 miles or so, your ecu should compensate."
Just regular road will do.
Old Oct 26, 2002 | 11:32 AM
jab969's Avatar
it dose not go over 45 either
Old Oct 30, 2002 | 06:03 PM
OZBOTS's Avatar
Post
None of our Lancers go over 45...THERE TO SLOW
Old Oct 30, 2002 | 06:56 PM
jab969's Avatar
I FIXED IT WHEN IT WAS WELDED THEY BROKE THE BEAD ON THE EXHAUST AND ALL THE PACKING CLOGED THE PIPE
akira2_03
21
Dec 5, 2016 01:46 PM
Jdizzo33
Dec 2, 2016 12:23 AM
crippled lancer
04-06 Lancer Ralliart How To Requests / Questions / Tips
Jul 31, 2014 05:13 PM
love9sick
Jun 13, 2009 02:23 PM
vr430
11
Sep 26, 2003 02:32 PM
