99 Eclipse Cyclone Engine
Old Apr 5, 2003 | 07:21 PM
PsykoB's Avatar
This is Billy again with the 99 Eclipse GS. On one of my recent post, I was replied that the cyclone engine would fit my car with the proper type of autotuning. Off anyone's 'top of head' what would I be looking to replace? The engine mounts, or the tranny--basically, what makes it differ from my right side tranny(?) of the engine to the supposed left side? Also, does the cyclone engine come w/ turbo-being at a 220 hp(sounds like a stupid question, I know) and how much torque is that? **Also, I'm currently running an open exhaust-question* does open exhaust add any sort of HP? Is open exhaust better, is open exhaust not good*--yes, I'm eventually going to buy a full HKS cat, but i don't happen to have 5 bills on me.
Old Apr 6, 2003 | 10:06 PM
dsmrider21's Avatar
For the turbo question, yes it is a turbo engine, and if you order the engine the tranny should come with it, and the cyclone engine I believe is still a right hand side transmission, it's still an eclipse engine, just the 1st generation engine. And isn't open exhaust when you run just a straight pipe out, I believe that that would increase flow very much, but you should run both a regular exhaust and then an open exhaust, I've seen setups where people just flipped a switch and it change the exhaust from running out of their cat and muffler to just a straight pipe on the side of the car. For what you have to replace like i said the tranny should come with it, and what you would need to do is get motor mounts, and change your ecu from what I know off the top of my head, I'm sure it has a little bit more invloved than that, but those would deff have to be performed with an engine swap.
Old Apr 6, 2003 | 10:22 PM
turbofreek's Avatar
the motor mounts are in comepletely different places, you would have to weld the new mounting points in, i haven't looked into this swap too much in a 2g, but in my 1g, it would require way too much sheetmetal relocation to make things fit. buy a gs-t motor and put on a cyclone intake manifold, thats the only real difference besides the turbo and the exhaust manifold.
crazy cunuc
10
Dec 22, 2010 08:51 AM
bvasquez12
13
May 12, 2010 06:20 PM
Rogercordia
Jan 18, 2007 08:17 PM
SlowCar
42
Jan 3, 2006 06:19 PM
kais3rboy
May 16, 2003 07:59 AM
