NEW PROJECT: SR20det 510!
. Take an old 30's ford or something to chop it. NOT feelin the gold grill either. Want a set of Fender Feelers and daytons to match?
for some reason i feel that car should have flames painted on it somewhere . . .
I live in Yuba city.its 40min north of SAC. Are you going to north or south lake tahoe? YOud take 80 if your going to south, and up my way if your going to north lake.
*************UPDATE************
Yes it is a floating dime
SHES IN!!!! welcome home
Houston we have a problem.....
Fuel rail is hitting the hood. AHHHH. My valve cover is about 1/4-1/2" from the hood. The fuel rail is about 1" to high. Any suggestions would be great. Different fuel rail? Different injectors? Speak up!
Shifter(stock..b&m should be here soon) Fits snug
ANd....with the cover
Anyone say dynamat?
Painless fusebox, sr wire harness, fuel pump relays, ignitor chip all tucked nicely into place. When the dash is on its hard to see it unless you look hard form underneath.
More room then I thought for the radiator. Going to get the crank pully machines off isince I have done away with A/c and P/S..which will make more clearence.
Body harness and Motor harness hid away becasue I want my engine bay CLEANNNNN. Motor harness will be under the intake manifold, body harness will be off the the very left hidden.
FMIC stickin out a Little bit but who cares. Also got some rubber surround so it doesnt rub. ITS TIGHT.. but I am still going to weld on some brackets
side view...paint is aweosmeeeee
thats it for now..... ENJOI!
BLing bling'n diff.
STOCK SUCKS
MY bros project;
CONVERTABLE 95 FORD AEROSTAR. YEs..the WHOLE TOP IS COMING OFF.. WINDSHIELD SHORTENED. MOTORIZED RAMP IN THE ABCK TO LOAD HIS/FIRENDS DIRT BIKES, AND GREEN ASTROTURF FOR CARPET WHEN IT RAINS.
you can see the lines where its gettin choped. Probably coming off this night when he has time
STOCK SUCKS
MY bros project;
