STi dyno results
Old Jun 4, 2003 | 04:19 PM
  #31
Braf's Avatar
Having driven both an Evo and an STi my impression is that the Evo makes its power at lower rpm. I have been spoilt by gobs of power at 3k. This may explain the different numbers for the two cars.
Old Jun 6, 2003 | 11:20 AM
  #32
KK's Avatar
KK
EvoM Administrator
I think you're thinking of the 2.0 Sti, whereas the US Sti has a 2.5L and makes far more torque than the Evo in the lower rpm range.
Mark
Old Nov 5, 2003 | 06:17 PM
  #33
nUrSpec's Avatar
Curious to know what the 360 put down to the wheels?
Thank you
Old Nov 5, 2003 | 06:38 PM
  #34
Boni's Avatar
sti > evo. end of story.
Old Nov 6, 2003 | 12:41 AM
  #35
spoolinEVO8's Avatar
End of story? Hardly.....
Ken
Old Nov 6, 2003 | 02:32 AM
  #36
CarPhoto.net's Avatar
Originally posted by shiv@vishnu
With the exception of the manual transmission that gets hung up when double-clutching down to 1st and 2nd gear, I can't think of anything on the car that I would like to change.
Cheers,
shiv
what is double clutching?
Old Nov 6, 2003 | 05:24 AM
  #37
inariv5573's Avatar
When I first saw the stock dyno results for the STi, I first thought to myself, wow! It is much less than the wheel HP of a stock Evo. Why is the STi losing so much power at the driveline! But then I read further the most powerful Evo made only 190HP at the wheels. I thought that can't be right. I see many stock Evo's making more power than that. Usually 230-240 at the wheels. How can a car making only 190hp at the wheels run low 13's and under 5 sec. 0-60's. Could you imagine thw power loss if you were to make 271 at the crank and only 190 at the wheels. Something must be wrong with the dyno. Pruven gets better numbers for stock cars on their dyno. Well over 200 at the wheels.
Old Nov 7, 2003 | 01:54 AM
  #38
ljasonl's Avatar
Cltuch in, gear shift to neutral, clutch out, rev engine to match RPM with what they will be after shifting down, clutch in again, gear shift to gear, clutch out.
shiv@vishnu
88
Jul 18, 2017 02:56 PM
shiv@vishnu
104
May 1, 2008 08:25 PM
shiv@vishnu
Jan 15, 2007 02:53 PM
CChow
Mar 23, 2004 02:00 PM
shiv@vishnu
Aug 13, 2003 02:11 PM
