I can turbocharge ANYTHING!
Just a bit of an update.. The motor is mounted with temporary motor mounts so I can trace some templates, The engine itself is sitting a little forward and may be a tight fit for the turbo. However The templates I'm tracing will lower the engine about an inch, and set it back about 2 inches.
I'm trying to find a good location for the pump, it looks like I may have to do it "indian larry" style with the pump hanging off somewhere, not my style unless I can find tiny inline pumps to use for the moment.
www.kikker5150.com The bike is small, but no moped or pocket bike..
The new turbo showed!! IHI RHB31
Their both nearly identical except for the flanges..
This turbo has a flange on its inlet that is about 2-3mm off on its bolt spacing from the carburetor.. if I elongage the holes on the carb's flange, it will BOLT UP TO THE TURBO! NO custom pipe or flanges!
I just need to find a phenolic spacer about the right size as the turbo inlet thats 1/2" thick or so..
Milburn
Fortunately I found a good source for Phenolic, Delrin, Nylon, and whatnot, I am purchasing a CNC machine in the next few months, basically a used bridgeport with a stepper motor and controller upgrade, but its expensive and my shop doesn't have the room for it now.
THe cool thing is I can actually create templates for things like phenolic or delrin spacers with O-ring sealing surfaces (no sealer required, so it acts as a reusable gasket and whatnot.
For the moment, I have two projects going on the same chassis at the same time.
Kinda late here but anyhow.Go to homemadeturbo.com.Theyll love this as the website is anything turbo and they do crazy stuff like this all te time.You can probably get a lot of help and info on their forum as well.
vegasboy301
Dec 12, 2005 06:30 AM
bloush, bloushturbo, bloushturbocom, bolt, dodge, durango, ihi, kkk, kp31, mitsubishi, rhb3, sale, td01, turbine, turbo, turbocharge, turbos
