What other cars boost as high from the factory?
Old Sep 7, 2007 | 11:40 AM
596736's Avatar
Just wondering what other past/present that boost as high as the evo straight from the factory? I believe an VIII is high 19 psi and the IX is just over 20 psi. Its amazing to me that such a high number on a factory block, its a real testament to the 4g63. I know the sti isn't as high
Old Sep 7, 2007 | 11:47 AM
TheBlueBlur's Avatar
It's easier to boost higher on these 2 liter 4 cylinder engines, than something bigger.
Old Sep 7, 2007 | 12:03 PM
Danny23's Avatar
From what i understand, the Evo 8 and IX,s are the highest boosted stock turboed cars sold. I could be wrong, but everything i have ever read about stock turbo cars these are the highest.
Old Sep 7, 2007 | 12:05 PM
AJsGenerX's Avatar
Cast Iron, closed deck block. Is this the reason?
Old Sep 7, 2007 | 04:26 PM
zbomb's Avatar
From what I've been told the AMG 12 TT makes 17psi in stock trim.
Old Sep 7, 2007 | 05:56 PM
596736's Avatar
interesting, thats pretty close. Any others? Does anyone know what the typhoon did?
Old Sep 7, 2007 | 06:30 PM
otter's Avatar
EvoM Administrator
I'm sure quite a few turbo diesels do.
Old Sep 8, 2007 | 08:27 AM
zbomb's Avatar
FWIW here is a dyno graph of said AMG tt. No lag with this bad boy. Full spool at 2K and 650ft/lb.
Old Sep 8, 2007 | 10:04 AM
BlueDemon's Avatar
^ 650 ft-lb of torque!!!!! Delicious
Old Sep 8, 2007 | 08:55 PM
battosaii's Avatar
hmm my SR20 stock is 7psi with a t25 right now im boosting 20psi with my GT2871 with stock internals and head only a metal headgasket and it it holds up well its weird how nissan made all their inline performance engines from the 90's way stronger then they had to be lol
Old Sep 8, 2007 | 10:08 PM
E. Haskell's Avatar
I believe Solstice GXP and Sky Redline peak at 20psi and sustain 18psi.
Old Sep 8, 2007 | 10:10 PM
theblue's Avatar
saab viggen boosts higher
The incredible power output of the Viggen's engine is primarily attributable to the larger turbocharger, which produces maximum boost pressure of 1.4 bar, or a full 20 psi, and is assisted by less restrictive air intake pipes and a performance exhaust system. Although only 15-16 psi of boost pressure may be required to achieve maximum power and torque at or near sea level, Saab's Trionic 7 engine management system allows the turbo to produce up to 20 psi at higher altitudes to compensate for less dense air. The result is maximum power is available at altitudes approaching 10,000 feet.
http://www.saabnet.com/tsn/models/2001/pr22.html
but we all must remember that psi of one turbo does not equal psi of another turbo in terms of power that it outputted. on a larger turbo you don't need as many psi to make the same power.
Old Sep 8, 2007 | 10:45 PM
fromWRXtoEVO's Avatar
Good info.
Carlos
Old Sep 9, 2007 | 01:51 PM
fox2boost's Avatar
i wouldnt mind one of those new solstice cars. they seem like they would be fun.
Old Sep 9, 2007 | 04:20 PM
theCybe's Avatar
Temperature, speed? I don't get it. Enlighten me with a link?
Thanks,
Noob.
