DSM Question
Old Dec 30, 2007 | 08:58 PM
bosox28's Avatar
DSM Question
I figured I'd post on here since there are a lot of people on here with engine building/dsm experience plus I'd get a much quicker response.
I have two questions, first is are Cometic metal HG's reusable? I got the HG new, put it on my set up and ended up having to pull the head off and use a different head, the block was decked originally and both heads were surfaced. It should be fine right?
Also, this setup (6 bolt swap in my 97 GSX) hasn't been driven yet, it's only sat in my driveway and idled as I've been working on other things as well. Now at idle (~1000rpm) its at 20inHg. Now I try to give it gas, it revs up etc, but once it hits 3000rpm, if you try to push it past it, it was sputter and not climb any higher, then once you let off the gas it sounds like a diesel truck after revving up lol. Anywhere above 2500rpm and then letting off the gas you can hear it.
Heres a vid http://s27.photobucket.com/albums/c1...t=MVI_0628.flv
Engine sounds pretty bad in that video lol, there is an exhaust leak in the manifold right now and the alternator belt needs to be tightened.
Any ideas? I know there is a small boost leak (like a pin hole) but there could be something bigger. Shouldn't the bov be opening up?
Old Dec 30, 2007 | 09:01 PM
Evo9Kid's Avatar
when u did the swap on the gsx did u put a new ecu in it? im assumign u did but did u have it tuned for the car yet?
Old Dec 30, 2007 | 09:03 PM
bosox28's Avatar
You don't need a new ECU and at the moment, I've just adjusted a few things with my SAFCII, thats it.
Old Dec 30, 2007 | 09:07 PM
Evo9Kid's Avatar
might be y its breakin up tho... my buddy did a 6bolt swap on his 96 and had the ecu not bein tuned right and it was breakin up
Old Dec 30, 2007 | 09:19 PM
90GSXDan's Avatar
Could be a bad mas or coil. Make sure its timed correctly. And for god sakes, get DSMLink!!!
Also sounds like really bad compressor surge.... Shouldnt do that on just free revving, its not like your putting that much of a load on the car either... Something is messed up.
BTW, get rid of cometic... Piece of garbage. Should just stay with the mitsu 4-layer.
Old Dec 30, 2007 | 09:28 PM
EmeryatSTM's Avatar
if you can, Get your self DSM link and bring it to a tuner... It will be worth every penny
-Em
Old Dec 31, 2007 | 04:34 PM
fromWRXtoEVO's Avatar
Call me nuts but I think the BOV is set too low and is letting the air to recirculate back into the Intake in great flow. Basically the air is not going much into the intake manifold and instead into the intake(turbo inlet).
The one clear indication to me was to hear the BOV opening at very low engine load. Typically at 300rpm and without any engine load the turbo only builds 3-5 psi. It is very extrenage to me that the BOV is already opening at such low PSI.
my .2c
Carlos
Old Jan 5, 2008 | 07:25 PM
90GSXDan's Avatar
What you hear is compressor surge.... I would do as mentioned, definitely get DSMLink as youll never look back. One of the best mods Ive ever done...
Dan
Hotsauce101
May 14, 2015 09:50 PM
10isace
62
Oct 6, 2013 10:29 PM
Jamesm331
Feb 29, 2012 08:32 AM
4g94T
Lancer Aftermarket Forced Induction Tech
18
Jan 4, 2011 06:38 PM
Alex Rodriguez
47
Feb 25, 2009 08:39 PM
